Maytag bravos mtw6600
WASHER GIVES UL CODE AT SPIN CYCLE AND IS DISENGAGING FROM THE MOTOR FOR THE CYCLE SO WHAT ELSE COULD CAUSE THIS ISSUE?
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Posted on Jan 06, 2009
  • 417 Answers
SOURCE: My Maytag Washer quiet seriouse
Hi
UL fault code indicates 'unbalanced load' which means the unbalance switch or control board may be faulty.
Sometimes it just means you have heavy items such as large towels or curtains in the wash but if it persists you will need to get it looked at.
Ash
Please rate this solution if you find it helpful
Posted on Dec 20, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a Maytag Bravos MTW6600 top load washer. I
Hi
When you hear a humming sound from the motor it means that the motor control is bad and should be replaced. If you still want to test the motor control then you can take it apart and test the motor before replacement. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 31, 2010
SOURCE: maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Posted on Jan 03, 2011
heatman101
  • 43501 Answers
SOURCE: Maytag Bravos MVWX600XW washer is
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Apr 17, 2011
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
UL bravo error code
Unbalanced load? Don't over stuff the washer. The load sensing moves the drum back and forth at the start. If it can't balance the load it will err.
Oct 16, 2013 | Maytag Bravos MTW6600T Top Load Washer
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
Tub does not move during wash cycle;just keeps filling;timer jumps from 25 to 4:then drains;flashes OL(small loads)
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
My Maytag Washer quiet seriouse keeps showing UL the last 11min of the spin cycle and I don't kno wats wrong
Hi
Ash
Dec 20, 2010 | Maytag Bravos MTW6600T Top Load Washer
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
