Question about Freezers
2175190 Lane sweetheart chest. Cedar lined. Style number 2905-23
What is date of lane cedar chest style 481939 serial no.145280
According to Lane, your cedar chest was made 8/25/14.
Usually Lane cedar chests have serial numbers that are stamped or applied to the bottom of the chests.
You can read the serial number BACKWARDS to determine the production date.
For example: serial number 753150 would have been produced on 05/13/57.
Some chests may also have an extra digit which denotes the plant location.
For example: serial number 2557121 would have been produced on 12/17/55 in plant #2.
Oct 06, 2016 | Freezers
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
Has power but does not freeze
About the only things that can be replaced on a chest style freezer are the thermostat, and the starting device for the compressor. if you know where the control is then thump it fairly hard to see if the unit comes on. If unit comes on then you need to replace the thermostat. (control and thermostat are same thing). now if it has the digital display on the door of the freezer do not thump it. Only the newer freezers have those though. Hope this helps
Mar 02, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
Can't find the temperature control on my Gibson "8" chest-style deep freeze.
its probable at the back down near the compressor just under the cabinet
Jul 26, 2010 | Freezers
The front surface of the chest freezer is
Hi, can you put your hands on front of freezer, and check from 1 to 5 without getting burn? how long can you keep your hands on front of freezer? check from 1 to 20 and let me know, normally there's a condensate line, or part of condenser lines that passes through freezer body , purpose of those condensate line is to prevent your door gasket from freezing , especially during winter. It's normal for front of freezer to be warmed, on hot days it will be a little hotter, you said "very hot" makes me wonder how hot it is, put your hands on front of freezer, use number method and let me know, but it's normal. good luck.
Aug 19, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Chest freezer won't restart
Probably bad thermostat- jump it out and see if it starts. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 21, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Frigidaire chest frezer kegerator conversion
The cabinet is the condensor. The lines run all around it. Unless you add an external condensor kit, the only safe place for holes is the door.
Apr 15, 2008 | Frigidaire 13 cu. ft. / 368 liter Chest...
Freezers Logo
24 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
