Question about Air Tools & Compressors
Need a wiring diagram for porter cable pancake compressor CFFN250N-2
2 Suggested Answers
  • 10 Answers
SOURCE: I have a Porter Cable
i think you got problem with your pressure switch.it doesn't switch off on the set pressure.. you can try to reset it and if it wont try to change it..
Posted on Apr 24, 2011
Porter cable pancake compressor will not shut off replaced manifold, still the same.
I would look at the pressure switch which shuts the electric off when the air pressure reaches its limit also check all wires going to and from this switch. Best checked with a multi-meter.
Feb 07, 2015 | Porter Cable Air Tools & Compressors
How to test electric switch on porter cable air compressor
What you need is something called a volt-ohm meter.
Obtain one and use it to test your switch and wiring.
May 26, 2014 | Porter Cable C2002 150 Psi 6 Gal...
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
I have a Porter Cable pancake compressor Model CFFN250N-2 which worked great last year. This year I turn it on and it just continues to build pressur euntil the safety valve blows.
i think you have a problem with the pressure control. unplug the compressor and open the controller. check all the connections and really look it over. these pressure switches today just do not hold up well. sometimes there is enough moisture in the unit that it can freeze over winter and crack. if yours has a plastic hose to connect then check that over as well. check this site. they have a good parts break down ans look ar parts 111and 112 and 113. all called pressure switch service kit.
http://www.ereplacementparts.com/porter-cable-cffn250n-type-compressor-parts-c-129_1662_3092.html
Apr 24, 2011 | Porter Cable Air Tools & Compressors
I have a Porter Cable pancake compressor Model CFFN250N-2 which when first stated will usually get up to approx. 135 PSI and shut off. However, after a few minutes the compressor will not get up to Max...
Hi, my name is John. Welcome to FixYa. Sounds like you are loosing air pressure somewhere, check for air leaks in the line and connectors. Thanks for choosing FixYa...John
Nov 22, 2010 | Porter Cable Air Tools & Compressors
Trouble building pressure
I would check the reed valves in the pump. One of them may be broken.
Jul 09, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Air Tools & Compressors Logo
20 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
