Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Freezing food in Frig especially lower compartments
My Kenmore 73503 model with the french doors freezes food in all three lower compartments in the frig making them useless for vegetables or beverages. The thermostat doesn't seem to make a difference. When it was new I had a sears repairman out who replaced the thermostat but that didn't fix it. It is now at least 4 years old but it was expensive new. Can we repair it?
  • KathleenW Sep 04, 2007
    Thanks Solution Guy!
    My exact model number is 596 73505200, Serial # is 10705880CL if that helps.
    When you say gut the fridge to look for the thermister, do you mean just the fridge part not the freezer? I can probably move most of the fridge stuff to my grandmother's fridge but not what is in the freezer. It would of course, be easier the less we had to remove.
    Dididsaythat - no, the fridge does not cycle on and off. I looked for adjustable vents. Didn't see any.
    I might add that I think the crispers are only worse because they are lower. The lower shelves on the doors also freeze liquids.
    The fridge is currently set to the lowest setting, "1" and the freezer is set to 1.5 almost the lowest setting.
    President:
  • 331 Answers
Kathleen, you'll have to provide an accurate model number from the inside of your fridge for us to pull up any tech data on it. Open the door and look toward the ceiling of the fridge. But, from what you describe, it sounds like a thermister problem not a thermostat problem. A thermister is a small, temperature sensitive device that communicates with the computer to tell it what temperature its' location is at any given moment. The computer then adjusts air flow dampers, defrost cycles and cooling times accordingly. There can be many thermisters in any given refrigerator model line. These are inexpensive to purchase and easy to replace, but sometimes difficult to locate. They are usually hidden behind a small plastic shell, that looks completely unobtrusive. But they are easy to recognize for they have 2 white wires going into them that are tightly bonded together. To find them, you'll have to gut the fridge (food, shelves and all) and look closely. Focus your attention toward the area of the problem, the lower shelves/crispers. You may need to pull the rear panel out to find it, but when you do replace it. (UNPLUG YOUR FRIDGE FIRST!) Hope this gives you something to go on. If not, provide your full model number so we can assist further.
Posted on Sep 01, 2007
  • 291 Answers
Is you refrig. cycling off and on?... sounds like a themostate if its NOT.. you might see if you have vents that have adjustments.. pull out the crispers and check for adjustable vents ... if there close them down some.
SOURCE:
Food freezing
Hi Susan,
I had the same problem with food freezing on the bottom of the compartment, especially the veggies. I had set the thermostat to 34 for cold beer but I guess the thermostat is off a bit. I put a thermometer on the bottom shelf to make sure that I had control of the temp and set my thermostat until it was 36 inside. The thermostat on the front reads 40. I guess that 38 might be the magic number for you.
Jun 18, 2014 | Whirlpool GI5FSAXVY Stainless Steel ...
The refridgerator compartment is freezing all the food
What is the complete model number list in the refrigerator section?
Oct 11, 2013 | Samsung RFG299AARS Stainless Steel (285 cu...
Freezer set at 0 fridge set at 37. thngs in fridge and crisper are freezing
this is a big problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Kenmore 73503 Stainless Steel Bottom...
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
Refrigerator leaking water from freezer compartment, freezing along walls of freezer, but running water out under door
Sounds like the defrost water drain is plugged up. It could be a piece of food wrapper fell into it, or something. What make and model is it? Top freezer? Side by Side?
Dec 30, 2009 | Refrigerators
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezing in frig.
Check the air dampers at the bottom of the fresh food section.They may have been moved to a open position. If so close them up some.
Otherwise the cold control thermostat may need to be replaced.
Mar 21, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
209 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
