Question about Garden
361 jonsered chainsaw oiler not working - Garden
dontbother10
  • 2220 Answers
SOURCE: chainsaw chain oiler not working
There is probably a filter on the bottom of a hose within the oil tank. Go through the tank fill cap with a blunted rod. Move it slowly you should find the hose. Draw it gently toward the opening. You can probably find a new filter at a Husqvarna (parent company) dealer if you don't have a Jonsered dealer handy. Oil pump replacement is complicated. Any good chainsaw mechanic can replace it regardless of what saw they sell. Arboristsite dot com is a buch of chainsaw nuts (Eye r 1). They will give you better guidance. Please do a searh in the chainsaw forum before asking "how do I fix my saw", the answer has almost certainly been asked. Spike60 is a Jonsered dealer and is always helpful. HTH Lou
Posted on Sep 02, 2009
SOURCE: need to know gas to oil ratio jonsered 535 chainsaw
50:1 is the mixture for the Jonsered 535. I bought mine new around 1991 and it's been a great saw.
Posted on Nov 09, 2009
  • 597 Answers
SOURCE: jonsered cs 2250 fixed flow oiler can the oiling
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
Posted on Dec 05, 2009
  • 4088 Answers
SOURCE: how to adjust chain and bar oiler flow
The chain should be adjusted so that the chain can be pulled by hand fairly easily, but doesn't droop from the bar underneath. Oil flow should be set so that a running engine (chain moving fairly fast) will send a thin line of oil off of the tip of the bar (onto a piece of cardboard) with a few moments of running. Hope this helps!
Posted on Feb 27, 2010
Testimonial: "Thanks for advice about oil flow !adjustment needed I think !!"
dontbother10
  • 2220 Answers
SOURCE: McCulloch EB428 chainsaw and the auto oiler won't work
Good on you for what attempted already. I looked at the print and it appears there is a worm gear (item 50) and a driven pump (item 61) behind the clutch. I suspect one of the 2 has failed. I know you have done most of this already But does it ooze with the bar off?
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
A link to the only IPL for a McCulloch EB428 follows:
http://www.ordertree.com/modelinfo/MCC/EB428-Chainsaw/139.EB428-Chainsaw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 30, 2010
Jonsereds 361 chainsaw appears to have fuel feed issue. When I add fuel to carburetor will run till fuel is depleted, but will not feed from tank. Fuel line clear and fuel tank is full. What is next s
1st. make sure the gas oil ratio is correct
always shack saw and gas can before starting, this mixes the gas & oil to prevent clogging and helps starting. hope this helps
Oct 22, 2016 | Garden
What is the gas/oil ratio for this chainsaw? Is synthetic oil okay to use in it?
Generally 2 stroke engines work on a ratio of 50:1
100ml of 2 stroke oil in 5L of petrol.
Use good quality 2 stroke engine oil for the mixture, Stihl and Husqvarna both have high quality engine oils, designed for more efficient lubrication and emissions quality.
Mar 28, 2016 | Garden
How do I change the sprocket on my Jonsered 621 chainsaw?
the sprocket is part of the centrifugal clutch assembly
go google and type in ---workshop manual for jonsered chain saws and there are pages of manuals
I opened one page named jonsered 2036 workshop manual --pdf download and it shows how to work on the chainsaw and includes other models in the procedures
that site is www.manualslib.com>brands>jonsered manuals> chainsaws>2036
Sep 26, 2015 | Garden
Jonsered Parts Model 361 & Model E61 Where can I find?
The 361 was a badged engineered machine, it was manufactured by TML in Canada, they produced machines for many other manufacturers, Danarm, Frontier, to name a few, it is an old machine from the mid 1980s, there are no parts available from Jonsered, but try the web for these other makes, Husqvarna had a machine much the same from them the Husky 35, and the Husky 37, try the web for these models.
Good luck
Feb 08, 2011 | Garden
Does my jonsered 451 ev have auto. chain oiler
yes it does. I have one and all I do is add chain oil to the reservoir and go. I've cut acres of trees and it always works great.
Sep 26, 2010 | Garden
My saw a jonsered 670 champ keeps putting oil out the oiler tube even when the saw is shut off , until the tank is empty any ideas or fixes?
Try loosening the oil filler cap when you are finished using the saw, this should stop the siphoning of the oil. Tighten the cap again. Stephen.
Sep 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi,i,m prtty sure the oiler for jonsered chainsaw has conked out
remove the chain and bar look twords the oiler and clean out that oiler port it works on gravitation thats all
Apr 24, 2010 | Hammering
The oiler on my ms 361 isnt working i tried cleaning it out but it didnt help what else could it be
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
You are not the one to have problems with teh oiler on a 361. Talk to your dealer, there may be an unannouced recall.
Sep 29, 2009 | Garden
Chainsaw chain oiler not working
Sep 01, 2009 | Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
