Question about Sharp Comfort Touch AF-R120EX Air Conditioner
Hello I have a sharp comfort touch Modle Af-r125
Trying to clean condenser coil cant get to screws
3 Suggested Answers
KOakaKO
  • 135 Answers
SOURCE: Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Posted on Aug 02, 2007
  • 3 Answers
SOURCE: I have a Sharp Comfort Touch AC displaying E-1. ??
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Posted on Jul 26, 2010
What is thru wall for comfort touch?
Never heard of it. Maybe it is an air conditioner that is built into the wall and works in two rooms.
Aug 25, 2014 | Sharp AF-S100FX Comfort Touch Air...
My air conditioner is freezing up
Hello, the unit will frost from either low airflow ( dirty coil or filter) or a low refrigerant charge due to a leak.
Jul 04, 2012 | Sharp Comfort Touch AF-R120EX Air...
Air conditioner not draining
Hello, some window units do not use a drain tube instead they use the condenser fan blade to scoop the condensate from the bottum of the base pan and splash the condenser coil to keep the condenser cool and also evaporate the condensate. Most of the time you can hear a "swishing sound" If the unit has a drain but is not draining then there could be a blockage that needs to cleaned.
Jun 19, 2012 | Sharp AF-S80FX Air Conditioner
My air is driping water inside
That's condensation; it's the humidity begin removed from your room. It's totally normal and you actually want it. Just make sure to tip the AC a little downward on the outside so that it can drip outside.
Aug 08, 2011 | Sharp AF-S120FX Comfort Touch Air...
I have a Sharp Comfot Touch AC - AF-121208W that I inherited from my brother years ago. I do not see a "drain" but can see water inside the unit. How would I get the water out? I do not see...
The unit will have a small amoount of water in it just make certain that it is tilted tot he ouside to help it drain. check the filter and clean it while your at it . let me know
Jul 23, 2011 | Sharp Comfort Touch AF-R120EX Air...
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
Air coming from unit smells bad.
You can buy some evaporator coil cleaner that doesn't have to be rinsed off. The normal condensation on the coil will take care of that.
Jul 30, 2010 | Sharp AF-R609X Air Conditioner
We have had our 12000 BTU sharp ac for about 10 years now. The unit seems to be working but is not cooling the room that well. How do I know if its the compressor or it just needs coolant? If it isn't...
Remove the unit and clean the evaporator coils and the condenser coils with a good coil cleaner chemical.
Oil the fan motor bearings.
Replace the capacitor.
Jun 27, 2010 | Sharp Comfort Touch AF-R120EX Air...
Sharp Comfort Touch AF-R120EX Air Conditioner Logo
32 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
