Leisure classic range 60 grb6cv setting the clock
How to set the clock for a leisure 60 GRB6CV
SOURCE: can't set clock on 2006 ultra classic
i have a friend who had a simular problem he pulled the maxi fuse out of the bike for 5 min , this is suppose to completely reset the radio
Posted on Dec 20, 2008
  • 3 Answers
SOURCE: Can you help me set the clock
TRy this page http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
Posted on Jan 20, 2009
  • 95 Answers
SOURCE: How to set clock on GE range
press and hold the timer key for 5-10 seconds see if it flash;s if so use the arrows for hour and min, comment back with all the setting/buttons it has other than temp for individual ranges :)
Hope this helps ya!
Posted on May 19, 2009
  • 69 Answers
SOURCE: 2002 harley davidson ultra classic setting the clock
Turn the Bike on and the Radio off and then follow the buttons on the screen. Most people think you have to do it while it is running and this does not work
Posted on Jun 28, 2009
jsrock516
  • 5911 Answers
SOURCE: How do I set the clock on a Maytag gas range, I
If your range is the same model as you posted this question under, the time is set by pressing the "CLOCK" button. The word "TIME" will begin to flash on the display. Using the keypad, press the corresponding numbers of the current time.
NOTE: If the oven has been programmed, or is in use, you cannot change the time. Cancel all other functions before attempting to set the clock.
If the model number is not correct, please post back with your correct information so that I may be able to provide you with better assistance.
Posted on Nov 01, 2009
Rangemaster 55 leisure. My timer has stopped working
Hi Stella,
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Feb 28, 2017 | Rangemaster LEISURE 55 & 110 FAN OVEN...
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
I have just moved into a house with Leisure rangemaster 110 dual fuel, how do i change the time on the clock have pressed all knobs in various sequences, found the automatic, the timer but cannot move it...
http://www.rangemaster.co.uk/Siteimages/Site_311/Pdf/ProfessionalPlus110DFOct08.pdf
User manual.
When the clock is first connected, the display flashes ( 0.00) and (?) alternately. To set the time, turn and hold the Timer knob to the clock symbol (?) and at the same time turn the Adjusting knob left or right until the clock shows the time of day. Remember this is a 24-hour clock. Let go of the Timer knob and it will spring back to the vertical, oven manual setting.
It is on page 6 of manual
Mar 28, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
SNK Fratelli Evolution FREV905S-S Stainless Steel electonic clock and timer running slowly
This is from Tim at JMAppliances 2/24/2011:
These clocks are built to operate at 50 cycles(Europe) and 60 cycles(USA) and this is controlled by the audible alarm setting. The clock has to be set on the loudest (highest tone) alarm for the clock to operate at the correct setting. You control the loudness of the alarm by pushing the minus button (second from the right) repeatedly until you here the loudest (highest) sounding tone. Leave it at that setting and the clock will work fine.
Hope this helps
Feb 09, 2010 | SNK Fratelli Evolution FREV905S-S ...
New applaince can't set clock, cannot switch on eletric ovens, electric grill works, gas hobs fine
I'm sure you must have had an answer by now, but just incase anyone else has the same issue. The ovens don't work unless the clock has been set (happens after a power cut). To set the clock you need to hold down the left-hand two buttons (underneath the clock) and at the same time press either the + or - button.
Oct 19, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
 Grubhead
Grubhead
