Question about Health & Beauty
Conair th300 scale
How to set the clock to 12 hour cycle not 24 hour cycle
SOURCE: 24 hour clock
Press and hold the time button til it flashes 12H.
Posted on Dec 11, 2007
  • 29 Answers
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Posted on Mar 12, 2008
SOURCE: conair ww39 glass bathroom scale won't work- batteries in wrong maybe? Help please!
Googled around until I found specifications for an unrelated brand of a similar bathroom scale. It mentioned making sure batteries were flat side uppermost in their compartment, which did the trick.
Posted on Sep 26, 2008
SOURCE: Conair WW36GD bathroom Scale
tanita 621 how do i change weight from cm to pounds??
Posted on Jan 18, 2009
SOURCE: change the time setting from 24 hour to 12 hour AM PM
Check this
Go to start>settings
Go to the system tab and the regional settings icon
Go to the time tab and it should be hh:mm:ss tt for 24 hour clock
Let me know how that works out for you
Posted on Mar 06, 2009
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
My conair model th300 is giving me a reading of 288.8 then it goes to err.
I was thinking there were too reasons for this, but I can't find the specs on this scale. One reason may be that its upper weight has been exceeded, but I think that is unlikely. My other thought is that the battery is failing. It is enough to make it come one, and to register your weight, but not enough to continually display it. The instructions indicate it has a 3 volt lithium battery in a compartment in the back.
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=0ahUKEwjintjyt97RAhVU1mMKHdGnCQQQFghCMAY&url=http%3A%2F%2Fwww.conairscales.com%2Fcatalog.php%3Fproduct_id%3D428%26ib%3Den&usg=AFQjCNEp2iyMiCxDasXeoxeI_3r1no7RTA
Jan 25, 2017 | Conair Health & Beauty
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
I got a package with 2 timers. I had no problem setting the first, but on the second, I want to use a 12-hour clock. Seems it came programmed for a 24-hour clock, and I can't figure out how to change...
Westek TE22 two-pack offers choice between 12 hour am-pm display or 24-hour 'military time' display.
Open following link for typical manual
http://waterheatertimer.org/pdf/TE22DHB-manual.pdf
Look at step 7 in manual under Clock Time Setting.
Step 7 says, "press - button for 3 seconds to choose display"
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | Hardware & Accessories
How to set clock?
You can set the clock to a 12 or 24 hour system.
For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
Mar 05, 2011 | Emerson MW8107WA Microwave Oven
I need to change the atomic clock from military time to standard 12-hour format...can't find original manual...have owned the Radio Shack clock for 5 years.
Hit the set button until the number 24 shows up instead of the time. Hit the "+" button once, and it will switch from 24-hour to 12-hour display. Hit the set button to cycle through the rest of the settings.
Jun 22, 2010 | SkyScan 86709 Atomic Wall Clock
I have the georg jenson wave clock but don't know how to toggle between the 24/12 hour clock. Right now it's set for the 24 hour clock and I live in the U.S. and want the 12 hour clock setting.
Well...this solution may be a few years late for the original poster, but I did figure it out on mine. If it's the same clock that sits on a rubber stand and you press the top edge back to activate the light, to toggle between 12 hour and 24 hour clock, you press the + and - buttons, simultaneously, for 3 seconds.
Jan 19, 2010 | Jensen Audio Players & Recorders
Setting clock in 12 hour format instead of 24hr
You can download the manual here: www.topeak.com/mediafiles/assets/341/file/1
By performing a reset and setup under section A. of the manual you can select 24 or 12hr time.
Jan 06, 2010 | Topeak Panoram V12 Mini 12 Function Cycle...
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
Dec 12, 2008 | Sharper Image SI785 Clock Radio
Health & Beauty Logo
51 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
