Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Washing machine top load
My fiance's grandmother's washing machine will pump water into the tub, but not out. I do not hear the motor engage in any cycle. I think she needs a new drive motor. Does that sound right to you? I replaced the coupling about a year ago and it had been fine ever since, until yesterday. Any help?
  • 164 Answers
It sounds like ti could be the lid switch. Some whirlpool models will fill with the lid open. even before cheking the switch for continuity open and close the lid and listen for the "click". Ifyou hear the click then check the switch for continuity.
Posted on Aug 31, 2007
GE Washer top-load WLDSR416FOWC
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Whirlpool won't dump water- top loading washer - Ultimate care
check the tub on down to the pump located on the motor for obstructions, then to the hose leading to the drain from the pump for obstructions,then possibly pump is bad
Dec 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine won't always spin on its own
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Since it will spin on lighter loads, the problem points to the clutch.
When the washer goes into spin mode, the motor is reversed to spin the pump and a clutch on top of the transmission engages to spin the tub.
Following is a description of how to access the clutch and check the clutch bands.
Sears and Whirlpool have a replacement parts kit for the clutch.
If the bands look OK, the problem could be in the neutral drain inside the transmission.
Oct 05, 2009 | Kenmore 24032\24036 Top Load Washer
I was washing pillows and water just overflowed - I'm not sure from where. I think the bottom of the machine. Just a little bit of water. Did I ruin the motor?
If you let the tub fill, then put the pillows in, you may have caused the water level to overflow the outer tub somewhat. If you didn't smell smoke or hear any frying sounds, the motor is probably ok. Does the washer seem to operating normally?
Jul 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loading washing machine water comes out of the bottom
whirlpool top load washer leaking water into tub with unit in off position
Jun 20, 2009 | Washing Machines
Washer tub will not move on any setting
Jan 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maybe the motor is shot, maybe the electronics are messed up. You might be able to siphon the water out of the tub.
Apr 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Could be the lid switch . You can bypass it to test it or if you hear the the motor trying to pump out it could be something stuck I the pump.. let me know what you find out..krazytech
Sep 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
