Wpp3915 how do u turn channels without having a remote
Stuck on 3 channels, no remote.
U can't get to channels 3 or 4 without a remote.Ur getting stuck on these particular channels 26,35 and 19 mean the last owner put these channels on the tv memory.Try website like Remotes.com to buy an exact remote or very close to the original,if u want make use of this tv.
Jun 15, 2010 | Sylvania 6420FB 20" TV
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
Remote stuck--can't change channel or turn off TV
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Jun 15, 2009 | Logitech Webcam
Child lock is on lg tv and have lost the remote
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
Apr 10, 2009 | Televison & Video
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
RCA tv with FiOs
my fiance fixed it. he has this really expensive remote that he programmed via a USB port and some fancy fingerwork that I can't even begin to explain :D and I was able to change the channel back to 00
Jan 20, 2009 | Televison & Video
Finding AV channel without a remote control
Hi, I brought a EmersonTV model EWF2004 without a remote control and I can't find the AV channel to watch DVD's I hope you can help me
Sep 01, 2008 | Emerson EWF2004 20" TV
Systemlink3
  1. Make sure the device you are programming is turned off.
  2. Press and hold CODE SEARCH.
  3. Press and release TV, VCR, or CABLE corresponding to the device to be controlled. The indicator light will flash once to indicate the search is enabled.
  4. Release CODESEARCH.
  5. Press OFF/ON repeatedly until the device turns on.
  6. Press CHANNEL V (channel down) for verification. DO NOT press any other buttons at this time.
If the channel changes on the device, the code is valid. Press ENTER to complete the search.
If the channel does not change, turn off the device (without attempting to use the remote). Then continue search by repeating steps 5-6. When all codes have been searched, the indicator light will flash twice and the remote will return to the normal mode.
May 03, 2008 | RCA Universal Remote 3 Device Remote...
Channels
If you have a menu button on the front of the Tv, you could search for an autoprogram or channel search menu and select that. Otherwise a cheap universal remote might be needed. You also want to make sure it is selected to receive antenna and not cable channels.
Sep 03, 2007 | Sylvania 6427FF TV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
