Tv manuel for wpp3915
How do u turn the channels without a remote
2 Suggested Answers
  • 308 Answers
SOURCE: Channels
If you have a menu button on the front of the Tv, you could search for an autoprogram or channel search menu and select that. Otherwise a cheap universal remote might be needed. You also want to make sure it is selected to receive antenna and not cable channels.
Posted on Apr 13, 2008
Stuck on 3 channels, no remote.
U can't get to channels 3 or 4 without a remote.Ur getting stuck on these particular channels 26,35 and 19 mean the last owner put these channels on the tv memory.Try website like Remotes.com to buy an exact remote or very close to the original,if u want make use of this tv.
Jun 15, 2010 | Sylvania 6420FB 20" TV
I have lost the manuel and remote for my GE49GW948
Best thing to do is to buy a universal remote - preferably RCA/GE brand since it will work without programming.
You should also be able to get to the autoprogram function of the TV by using the front panel buttons.
Oct 19, 2009 | GE 46GW 948 46" Rear Projection Television
Child lock is on lg tv and have lost the remote
My child lost the tv remote and we have the child lock on so we can;t change the channel or the volume. Do you know how to turn it off without the remote?
Apr 10, 2009 | Televison & Video
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Universal Remote Codes
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes the direction to forward again.
5. Press and release MUTE to install the code.
Jun 11, 2008 | Philips PM435S Remote Control
Hello
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
May 09, 2008 | Philips Universal PH301S Remote Control
Magnavox Model # RK 5530 AK02 TV
Can you get to inputs on your tv ? I would use these inputs rather than channel 3 because you'll get a better picture using the inputs rather than the tuner. They are in the back Yellow for video and red and white for audio. But without the remote you can go into the menu to see if you can manuel program your channels but most of these sets you can't do that . www.replacementremotes.com might have your remote should you need one . Good luck
Mar 01, 2008 | Televison & Video
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
