Question about JVC LT37XM48 LCD TV
No left side of picture
Until set is warmed up no left side of picture
How do I set time and date
To set the clock, have good batteries in. Slide the selector to Setup (middle setting).
Push the large right button marked MENU.
Push one of the right side buttons, above the word SHOT, these are the right > and left < buttons. Push repeatedly until you see
Set Mode
Set Clock
Set where the last Set should be outlined in dark. Now push the OK button which is the large left button.
Choose the field to update with the right side buttons > or <, once you have the one to update, use the left side up and down buttons to change the value shown until it is correct. Choose the next field with the right side < or >, update the value with the left side buttons. Only when you are completed with updating all of the date and time values, do you hit OK to set them all.
After this all pictures will have the correct time available. Though you have to choose in one of the other menus whether to show the timestamp on the picture. The picture will have the date and time associated with the file when you take the card out to view it later.
Jul 02, 2015 | Simmons 119422C ProHunter Trail Cam 6mp...
Partial picture frozen
Hi Robert
Possibly bad video memory.
LSI Chip failure until warms up.
Feb 24, 2014 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
My 47" Vizio is darker on the left side. Used to be I would turn it on and once the TV was warmed up the picture would be perfect. Then one day it just stayed darker on the left. Everything else works
More than likely you have a bad LCD panel tab. The only true fix is the replace the panel. There are companies who will repair the tab but the cost of repairing the tab, and replacing the panel will exceed the cost of a new TV set. There are youtube videos of fixes but you will have to take the entire set apart.
Apr 08, 2013 | Vizio VO47L 47 in. LCD TV
Panel issues with sony kdl-hx800
That sounds like a defective LCD panel tab connection. Does it go away if you tap the left side of the set? Or does it clear up when the set warms up?
Nov 27, 2012 | Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
Black lines in tv
Most likely there are electrolytic capacitors in the power supply, video path, and scan amplifiers that are starting to fail from age. This is common in many of these sets. In consideration of the age of the set, this may not be worth having it serviced.
Jerry G.
Sep 24, 2009 | Toshiba 51H93 51" Rear Projection HDTV
Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
Shifted Picture
Yes. This problem comes about by actually pressing the center ring accidentally during normal viewing. Just press and hold the left or right side of the ring until the pciture straightens itself out again (if the black portion of the screen is to the right of the picture, press the right ring; if it is to the left side, press the left ring).
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 51PW9363 51" Rear Projection...
JVC LT37XM48 LCD TV Logo
21 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
