Question about Edirol UA-4FX External Sound System
Recording Device Not Listed
In Audacity, I go to Edit-Audacity Preferences, using my new Dell C-521 PC. Under "Playback Devices" the list of devices includes "Speakers (UA-4FX)." But no UA-4FX is listed under "Recording Devices." On my Lenovo laptop, my UA-4FX workds fine. (It IS listed on my laptop as a recording device.) Any ideas what I am doing wrong on my desktop PC?
  • 689 Answers
You need to install the driver accordingly, When you buy the product it comes with installation Disk. If you dont have it now still you have solution simply download the driver from the manufacturer's website
Here is the link
http://www.rolandus.com/products/productdetails.aspx?ObjectId=758&ParentId=114#
Good Luck
Posted on Feb 05, 2008
6ya staff
SOURCE:
Microphone doesn`t work
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable Hope this helps.
Jan 05, 2013 | Dell Inspiron 15 1545 Notebook
I'm having trouble with figureing how to set up my microphone to the computer
Dec 12, 2012 | Dell Dimension 4600 PC Desktop
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
Getting lidl silvercrest turntable / audacity to transfer records to computer
Assuming you've installed the Audacity software, first check your recording device. If you use Windows, first check the Audio Control Panel. For Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click on the Manage Audio Devices link. In that window, click on the Recording tab. Select the USB option and make it the active device.
In Audacity, you may also need to make sure that this is the recording device that is active. That should be the third drop down from the left in the Device Toolbar. (If it isn't visible, click View > Toolbars and check it.) The Device Toolbar is right above the recording trace section in my version of Audacity.
Now click Record (the red circle) and start your turntable. Do you see a change in the trace? You should see a flat line for up to 10 seconds and then see this change to a set of high and low values.
If you don't get this, check if your USB ports are working. If you use a USB hub, try a direct connection. Check the device manager under Universal Serial Bus for a triangle with a red x or a yellow triangle. Try updating the driver by right clicking on the device. Also check Windows Update (for an optional update) or your computer manufacturer site for a new driver.
Unfortunately with the USB, you can't hear the recording as it is made. Do a short recording and then stop it. Then play back the selection. Adjust the input volume level lower if your trace is hitting the top of the box. This is clipping and your recording won't include the full signal from your record.
I've used Audacity for recording cassettes through the line in port. You can do this with some turntables if you add a pre-amplifier and use RCA to 3.5 mm adapter. Connect to the line in on the back of the desktop (blue).
If you could not install Audacity, go to http://audacity.sourceforge.net/ to get a version that works on your computer's OS.
I hope this helps.
Jul 05, 2012 | Audio Players & Recorders
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
New microphone will not record...please advise.
There are two separate settings in control panel for record and playback - see below
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 20, 2011 | Dynex Voice-Certified PC Desktop...
Just installed new motherboard and now receive following message......itunes has detected a problem with your audio configuration. Audio/Video playback may not operate properly. How do I fix this?
Try reinstalling quicktime. Go on control panel uninstall quicktime. Then go to this url:http://www.apple.com/quicktime/download/win.html
Download it again. And install it again. Itunes should now work.
If it doesn't, for Video problems: Open QuickTime Player and go to 'Edit' -> 'Preferences' -> 'QuickTime Preferences' -> 'File Types' -- check here to see if the file format of your problem video files is selected.
For Audio problems: Open QuickTime Player and go to 'Edit' -> 'Preferences' -> 'QuickTime Preferences' -> 'Audio' -- Here you will see a Device is needed that will play your sound. Select 'Audio Playback and Recording Devices', If you are having an Audio problem it may be due to having no device or an improper device.
Good Luck
Nov 25, 2009 | Dell Dimension 9200 PC Desktop
Imic mon only-left channel is all that is seen
Audacity with Griffin iMic under Vista
There is limited and conflicting advice on the web about whether the iMic audio-usb adaptor can be used with Vista (for those who discover that new laptops commonly lack a stereo line-in port, and seek some way to use Audacity as described in the tutorial on capturing music files from vinyl, tapes etc).
In my case at least (Vista business 32 on a Thinkpad X200 with inbuilt Conexant Smartaudio 221 soundcard), it could be made to work as follows:
1. Plug the iMic device (iMic2 in my case) directly into a usb port on the computer. Allow the automatic loading of drivers by Vista.
2. Via control panel or right-click on the speaker icon in the system tray, access the Vista configuration for Sounds.
3. In the Recording tab, you should now see the added iMic usb device (probably designated as a microphone). The default set-up seems to be mono - so you need to make this change for this device: select Properties, Advanced, "2 channel...44100 Hz... CD quality".
I also disabled the built-in laptop microphone so there would be no chance of it interfering with recordings (or software conflicts?) - not sure if this is relevant but easy to test in the event that you strike a problem.
4. In the Playback tab, decide what you want as the default speakers.
The default seems to become the usb adaptor, but I changed back to the built-in speakers for monitoring - not sure if this is relevant but easy to test in the event that you strike a problem.
5. In Audacity (1.3.6 beta in my case): under Edit, Preferences, Recording, choose the iMic device and stereo. Project rate at bottom left of screen should match the quality chosen in Vista set-up for the device (44100 Hz).
6. While in Audacity, Edit, Preferences, Playback, choose the desired speakers (the built-in laptop set in my case) and click "Software playthrough" if you want to monitor what is being recorded (with a slight delay).
7. Immediately testing the set-up to record generated an Audacity "error while opening sound device". This only seemed avoidable by going back to mono settings in various places. BUT all is not lost...
8. Reboot! (With the iMic device connected in my case - not sure if this is necessary.) Ta-da ... all now works as desired for stereo recording. Use the same usb socket for the iMic in future, or you will have to repeat the set-up for each usb socket.
9. The Audacity volume sliders do not work under Vista, but you have several options to adjust recording volume:
(i) Use the slider under the Vista configuration for Sounds, Recording, iMic, Properties, Levels. For me this introduced a lot of hum at high settings, so I recommend keeping it below 5/100.
(ii) Use the iMic slider switch in the Mic position rather than the Line position, and fine tune as in (i) above. For me this gave the lowest background noise/hum.
(iii) Use the headphone out from your hi-fi amplifier and control volume there. This gave more background noise for me.
10. Keep the iMic device away from power supplies (it can pick up hum) and any source of vibration (if you tap it you will see a spike in the signal) while recording.
If you get hum, check whether it is from your laptop power supply (unplug and record using the laptop battery to see if the hum disappears). In my case there was unbearable hum from an iGo Juice supply, but much less from the Lenovo power brick.
After all that it is just about as good as my old Thinkpad X31 which has an inbuilt line-in socket and Soundmax audio card under XP.
With any luck the same approach will help with other ‘new, improved’ (but lacking line-in) Vista computers.
Aug 15, 2009 | Apple Griffin iMic External Sound System
I cannot access the turntable thru my USB hub.
I received an updated driver from Numark but that still did not solve my problem. It turned out to be some sort of incompatability with my USB 2 card. When I plugged the turntable into my old USB 1 slot, my computer recognized it immediately. The new Audacity and MixMeister programs that were sent as a fix from Numark are just burning programs and not drivers for the device. I can now convert my old vinyl with ease.
Mar 10, 2008 | Numark ttUSB Turntable
Edirol UA-4FX External Sound System Logo
132 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
