Question about Echo Garden
Echo HC 2500 runs poorly after 10 mins
My hedge cutter suddenly started running poorly, I couldn't get it to rev and it wouldn't tick over. I played with the carburettor, cleaned it and replaced the diaphrams to no avail. I then bought a new Walbro cerb and fitted it. It ran perfectly for about 20mins and then exactly the same problem. I have also changed the fuel filter and checked the fuel lines. I assume the next move is a press/vac test.
4 Suggested Answers
  • 110 Answers
SOURCE: echo manuals hard starting hedge trimmer 1500
all echo manuals are available on line at echo.com for free
Posted on Nov 01, 2009
dmiesner
SOURCE: ECHO HC-1500 hedge trimmer wont stay running cuts off
Replace the fuel cap.
Posted on May 29, 2010
  • 640 Answers
SOURCE: My 10 year old weedeater
I would check for spark and check the fuel lines, especially if fuel is left in it. Also if fuel left in you will have to empty the lines and carburetor or pull it enough to clear. Another thing to consider is that if fuel was left in it that the carburetor may need a rebuild, replacing the diaphrams.
I hope this is helpful for you.
Posted on Aug 26, 2011
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
I have a echo HC-150 it won't stay on boggs down
Hi, either the carby is flooding and requires a carby kit or the spark arrestor or outlet in the muffler is blocked. Hope this helps, regards Phil.
Jul 18, 2011 | Echo Garden
HEDGE TRIMMER IS EASY TO START AND RUNS GREAT AT HIGH SPEED BUT WILL NOT IDLE. ALSO IS SLUGGISH IN RESPONDING TO THROTTLE. Have replaced diaphraghm assemblies and fuel lines
You have two adjustment screws on the carb, one is for adjustment the mix at idle and the other under throttle conditions. You can tune the engine by ear. Refer to your manual for which screw is which. If you don't have it you can figure it out by letting the engine idle and give one of the screws a half turn (CC or CW doesn't matter) if that affects the idle condition readjust that screw back to the original position and proceed to adjust the other screw with the throttle full pressed. You will be able to hear the engine lean out or when it runs too rich, simply listen to the engine for when it starts to rev properly.
Jun 29, 2011 | Echo Gas 20 In Blade Double Reciprocating...
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
Looking for owners Manual for Echo HC 1500 Hedge Trimmer.
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
Apr 02, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Open Questions:
Garden Logo
55 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
