Question about Lexmark Wheelwriter 3500 Typewriter
Code 215 ibm - Lexmark Wheelwriter 3500 Typewriter
  • Lexmark Master
  • 3,594 Answers
I believe that code is a printwheel error Try try removing the wheel nand blowing that area out with some air.
DickyO
Posted on Jul 29, 2013
IBM Wheelwriter 30 Series II is showing an error code of 215 with a box with a slash through it and am unable to type on it
215 is a Print Wheel error. Remove the print wheel, look for debris in the P/W area, if you have a compressed air source blow the P/W area out. If these don't work the P/W sensor is probably bad.
DickyO
Sep 07, 2011 | IBM Wheelwriter 30 Typewriter
Error 215 code. Looks like a small part that is attached to a spring under the daisy wheel is either broken or loose.
215 is a print wheel error. If you have the "FLAG" broken it will have to be replaced. You will probably need a tech.
DickyO
Mar 15, 2011 | IBM Office Equipment & Supplies
Code 215 comes on with a loud noise....what can I do?
215 is printwheel error. Remove the printwheel, look for bent or broken spokes of debris in thst area. If you have some cammed air blow out that area, Try another printwheel.
DickyO
Feb 28, 2011 | IBM Wheelwriter 30 Typewriter
WHEN DEPRESSING THER SPACE BAR, THE PRINT WHEEL BACKSPACES INSTEAD OF ADVANCING TO THE RIGHT. I'M ALSO GETTING A 215 CODE.
You are probably in centering mode code "C" should get you out of that. 215 coce is not sensing the printwheel, remove theP/W, look for debris in that area, if you have some canned air blow the area out. If the problem persists you will need a printwheel sensor.
DickyO
Nov 08, 2010 | IBM Wheelwriter 30 Typewriter
Error code 215
215 is pwintwheel error. First check to be sure the wheel is fully seated and spins when T/W is turned on. If it does then remove it and look for debris in the area where it sits.
DickyO
Feb 18, 2010 | IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 30 SERIES II
I believe a 215 code is a bad printwheel sensor. You need a tech.
DickyO
Mar 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 25 message: a box and diagonal line thru it and the number 215.
Code 215 is a printwheel error. Remove the P/W and look for debris in that area, if you have some compressed air source blow this area out, if this dosen't do it the P/W sensor or the LED are probably going bad.
DickyO
Nov 01, 2008 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 30 series 2
215 indicates a printwheel error. Remove the printwheel, look for debris in the P/W cartridge and the area where it sits blow out the P/W area with air if the problem dosen't go away the sensor is probably bad.
DickyO
Apr 01, 2008 | IBM Wheelwriter 30 Typewriter
Code 215
Sounds like a keyboard problem, try unpluging the key board if the condition stay the same its bad, yoy can replace it or try this.
The rt. connector has seven of the connections on the rt. bussed together, wrap a piece of foil over the seven connections this should solve the problem.
BE SURE TO JUMPER ONLY THE CONNECTORS THAT ARE JUMPED ON THE RIBBON CONNECTOR!!
DickyO
Dec 28, 2007 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 3500 Typewriter Logo
99 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
