Question about Electrolux EW1000i Front Load Washer
No display at the monitor...no indications whatsoever.
  • Official Brand Answer
  • 4,342 Answers
Hello app_3rp71756, thank you for your question! You may try and reset the washer by disconnecting the power to the unit for up to ten minutes by flipping the circuit breaker off and back on. Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Other possibilities are: experiencing an issue with the door lock assembly, faulty control board, timer/pump, damaged cord, and a potential wiring failure. Because it could be a number of any one of several underlying caused, I would recommend reaching out to an expert to properly diagnose and repair the unit.
Posted on Jul 29, 2013
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Nothing will display on the monitor. Power button
More likely to be bad capacitors (bulging top/seal) in the power supply, that will be the first palce to start, post back what you see inside so we can guide you further (it can also be bad inverter circuits, main power supply, etc), see example of failed Samsung monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 13, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Same issue with no words
This is usually caused by the cable between the monitor and computer being disconnected (or partially disconnected) or damaged. Video card failure on the computer can also cause this as well. If you have access to a laptop, or friends laptop, try plugging in the monitor to the laptop. If starts working correctly, then cable was unplugged or video card has failed in computer. Also check cable connection on back of monitor.
Aug 25, 2009 | Gateway FPD1975W 19" LCD Monitor
No monitor display
Return the monitor. I had one like that and I replaced it with a Dell.
Mar 23, 2009 | Acer AL2016W 20" LCD Monitor
Monitor only flickers - no display whatsoever
You can purchase and aftermarket monitor. I bought a nice LCD from Wal-Mart for about 99 dollars. Also, tigerdirect.com sells refurbished and new monitors relatively cheap.
Mar 21, 2009 | Dell Dimension 3100 PC Desktop
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
No video at all on Compaq ProLiant 1850R
Do the server has an onboard Video disable the video in the BIOS setup insert another PCI Video card and check for the display , IF the PCI display is up then there could be a problem with Onboard card.
Nov 27, 2008 | HP Compaq ProLiant 1850R Server
No Display.
the problem is seem to be in your moniter vedio driver ic which is present inside the moniter it is programmable ic, it may get heated or corrupted so pls check your moniter
the service manuals are available at eservice.com
Mar 18, 2008 | ViewSonic VA2012WB Monitor
No post (blank screen) after intial driver install Acer 1716 LCD monitor
Please clarify something for me, after installing drivers, system reboots, and you have no POST information or startup screens at all?
Dec 15, 2007 | ATI RADEON 9550 Graphic Card
Monitor port not working
if you have'nt already, try changing motherboard setup configuration.
Mar 25, 2007 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Electrolux EW1000i Front Load Washer Logo
19 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
