Question about Dehumidifiers
Westinghouse Heavy Duty 25 Dehumidifier frost on coils
Westinghouse Dehumidifier frost on coils
  • the FACE
    the FACE Oct 14, 2013
    I believe they mean ICE, Mike; while a little frost may be normal, mine had virtually none, and was working GREAT until about a week ago. Now out of nowhere, afer several minutes, there's hard ICE on the coils...and - once that happens - not "a drop (of water) in the bucket!"
MIKE - I have the same problem...previously, there was NEVER any frost, and the unit worked just fine. Now, all of a sudden in the last week, frost has been forming...water no longer traverses thru the tube into the sink...and the unit is basically useless/
I think when the original person said "frost", they meant ICE!
Posted on Oct 14, 2013
SOURCE: Dehumidifier frosting up
I have the same problem under 5 year warranty. The Authorized May Tag Dealer (Stan & Pauls), advised that they were unable to duplicate the condition. I then took it home, let it run for several hours and brought it to them with the Evaperator completely frozen in ice. They then ran it in their shop and stated that it will not freeze their. It is interesting to note that this model is supposed to detect, icing and shut the compressor off and turn the fan on high for a while. Evidently this feature does not work on mine and can not be repaired. No more Maytags for me.
Posted on May 11, 2007
SOURCE: Edison 25 dehumidifier coils frosting
Same problem with mine.I've tried to clean mine as well. HELP, I live in a very woodsy area and constantly fight humidy.
adrianam@wpa.net
Posted on Jul 13, 2008
  • 252 Answers
SOURCE: The coils on my dehumidifier are frosting over.
Are the coils clean? If it has a filter is it clean? If yes to both, it has lost (leaked) refrigerant and it's time to buy a new dehumidifier. If the leak can be found it probably wouldn't be repairable and would cost more to fix than it's worth.
Posted on May 06, 2009
  • 52 Answers
SOURCE: dehumidifier coil frost up
Hi Eric where do you live? what is the Air on temperature i the basement? what is the Air off temp in the Basement? what temp difference are you getting.I ask where you are located in the world so we can work out the Ambient temperatures in the area.
Posted on Jun 08, 2009
  • 16 Answers
SOURCE: ice forms on the coils of a white westinghouse dehumidifier
if the filter is clean than it most likely is low on freon with the right tools you could add freon
Posted on Jul 07, 2009
Why does Frigidaire dehumidifier LAD704DUL has ice on the coils?
Hello Friend, thank you for your question!
I see that you have frost accumulating on the coils of your Frigidaire dehumidifier, LAD704DUL. Typically frost appears on coils either because your dehumidifier has been turned on recently or the room temperature is too low. Sometimes this is normal due to refrigerant rushing through the coils and usually it disappears within 60 minutes. However, if your dehumidifier is not removing moisture, then at this point your dehumidifier may possibly been experiencing a sealed system issue. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Hope this helps! - Z
May 15, 2014 | Frigidaire Dehumidifiers
Coil frosts within 15 minutes in a warm room. After 1-2 hours they coils are covered with snow like frost 1 inch thick.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 30, 2011 | Goldstar DH304 Dehumidifier
What can I do to prevent my Dehumidifier from building up a heavy coating of frost over all the condensing tubes. The dehumidifier is currently located in the basement.
The frost is requried for the unit to do it's work. The unit should routinely turn off and the ice should melt. without this process no water would be removed from the air....
Apr 10, 2011 | Dehumidifiers
Frost
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier2_bing.gif is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
May 17, 2010 | Goldstar DH304 Dehumidifier
My dehu has frost on coils most of the the
if the room air is cooler than the dehumidifier then they will frost over. normally frosting over means loss of freon but because it is a closed system there probably isn't. if the air's moisture level [humidity] is low then don't even run the machine.
Oct 25, 2009 | Ebac BD80 Dehumidifier
Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Jun 02, 2008 | Goldstar DH5010B Dehumidifier
Friedrich dehumidifier
Dave E. (Illeagle)
Jun 01, 2008 | Friedrich D50C Dehumidifier
adrianam@wpa.net
May 12, 2008 | Edison 40 Pint Dehumidifier
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
Dehumidifiers Logo
195 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
