Question about Boston Acoustics MicroMedia Computer Speakers
Replace subwoofer driver
Have a Boston Media Theater System (PN 7000947) System that came with a Gateway computer. Subwoofer is blown. Can I get a replacement speaker driver from Boston or equivalent? Looks like a 5" driver with a PN 304-1E0007-00 printed on the back.
SOURCE: Boston Acoustics Computer Speakers no sound
This speaker system requires a digital audio input, which most older systems don't have. The sound card that was built into your Gateway can put out either a digital or analog signal depending on how you have it set. Chances are your new sound card might be able to output in digital mode as well, but you may have to turn it on manually. Try double-clicking your volume icon in your system tray, then click the "advanced" button at the bottom left. This should bring up a window that lets you adjust the treble and bass, but it should also give you an "other options" area that lets you turn on digital output. If your new card supports digital output, the option should be there. If the card does not support it, you will have to use a different card. I hope this helps.
Posted on Apr 13, 2007
Al42
  • 72 Answers
SOURCE: Getting humming sound from all speakers. BA 700569 MicroMedia
It sounds more like the power supply is at fault (a filter capacitor dried up), but it'll take an oscilloscope to verify that - take it to a TV repair shop (if you can find one) or find a ham radio operator who still has test equipment. (If it happens even from an iPod, it'll be easy to troubleshoot, since the person doing it can use any audio source to cause the problem.)
Posted on Feb 09, 2009
SOURCE: Boston BA790 Subwoofer Making Strange Noises
I just took my sub apart and found that the surround on the driver speaker inside the sub was totally crumbled and lying in pieces throughout the sub box.
I'm looking around now for specs on the sub speaker so I can find a replacement.
Posted on Feb 15, 2010
Evan_royer26
  • 60 Answers
SOURCE: i have Boston Digital BA735 subwoofer speaker,
ok from the information you have presented i believe you have to get a male to male adapter for your sub woofer then plug it into your speaker in on the back of our comp and into your analog in on your speakers, please provide more information if this doesn't work and i would be happy to assist you further
Posted on Mar 21, 2010
bronk50
  • 27725 Answers
SOURCE: Boston Acoustics BA745 2.1 Analog Speaker System.
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer hope this helps
Posted on Apr 11, 2011
Loud humming sound
Make sure that the input connection ground is good. If that does not cure the loud hum then you have a power supply issue.
Oct 27, 2015 | Boston Acoustics Boston Acoustic Micro...
Subwoofer not working
There may be an internal fuse that's blown. I'd take it to a repair facility and have them check it. Could also have a bad connection inside. Good luck!
Feb 15, 2014 | Denon DHT-1513BA Home Theater System
Need input cable for p/n 7000947 subwoofer
Just the input cable? It's just a standard 3.5mm AUX cable. You can get a new one anywhere. They even have them in the checkout aisles of Walmart, since so many cars have an AUX input these days. Any 3.5mm to 3.5mm cable will work. And I know this because I have 2 of the same system.
Jan 27, 2014 | Boston Acoustics MediaTheater Computer...
Boston media theater system 7000684 input plug broken
better idea .... set FM transmitter in your laptop & receive audio signal with FM receiver.
or" connect external EP socket.
May 28, 2012 | Audio Players & Recorders
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
7000684, 7000787, 7000947, 7001364 power cable for gateway 2000 media theatre
In DEC 1998 I bought a Gateway PC with a Digital Media Theater, P/N 7000787. In the meantime the speaker in the sub-woofer got damaged (because of age). Is it possible to disassemble the sub-woofer and replace the speaker?
Where can I buy the same or a very similar speaker for this sub-woofer? Thanks, Andy Szekely
Mar 02, 2010 | Boston Acoustics MediaTheater Computer...
I have a Boston Digital BA735 Subwoofer. I would like to connect it to my current system. I running on Microsoft XP Home Edition 2002, Gateway FX400 Pentium (R) D CPU 2.8 DGhz, 2.8 Ghz 500MB RAM. Can I do...
I have a Boston Digital BA735 Subwoofer. I would like to connect it to my current system. I running on Microsoft XP, Dell Latitide 610.Can I do this? If so, do I need a different audio cable connector cord? Thanks
Nov 18, 2009 | Boston Acoustics BA735 Computer Speakers
Boston Acoustics MicroMedia Computer Speakers Logo
29 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
