Change thermal fuse on duet front loader ggw9200lw1
Where is it located in the dryer? How do I access it?
jsrock516
  • 5911 Answers
SOURCE: sour smell coming from inside whirlpool duet front loader
Residual water sits inside the wash tub under the stainless steel basket and in the drain lines & drain pump. This is normal. If you are in the habit of using very few hot water cycles and do not leave the washer door open when not in use, bacteria, mold and mildew can build up and cause the sour smell you are experiencing. The following link provides some good info on how to prevent these odors:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
You may also want to remove the drain pump reservoir and check to see if you have anything caught. Sometimes debris can build up in the drain pump and cause odors. The following link explains how to check the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I personally own a front loader such as yours and have never had a problem with odors by following this simple advice. Occasionally run a sanitary cycle with nothing but bleach in the water. For washers with no santitary cycle, run it on the hottest setting you have. Sorry...front loaders require a bit more TLC than conventional top loaders. I hope this helps you. If you have questions, please let me know.
Posted on Aug 18, 2008
danromarris
  • 101 Answers
SOURCE: My Kenmore 90 series dryer won't heat
The thermal fuse is going to be located on the heating element housing. When you take off the front panel you will see your lint screen housing. You will need to remove that to get to the element housing. Once that's out of the way the thermal fuse should be right on top of the housing. It is small and has two small wires coming off of it. The wires should be different colors. Just don't get it mixed up with the thermostat. Just match it up with the new one that you have. It is held in place with two small screws. Let me know if you have any other questions or still can't find it, also let me know if this was helpful. Good luck and glad to help out.
Posted on Jan 22, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Posted on Feb 09, 2009
  • 686 Answers
SOURCE: Maytag LSE7806ACE dryer stopped working
pry the top up at the corners and remove attaching screws for the front panel and remove carefully. Now you should be able to see the canister that contains the heat element and the thermal fuse. If your thermal fuse is bad you also need to replace the high limit thermostat switch which is located on the canister itself and check that the heating element is not broken anywhere throughout the coil.
Posted on Apr 06, 2009
  • 1294 Answers
SOURCE: i have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Posted on Apr 08, 2009
Whrilpool duet dryer will not start
More than likely the thermal fuse has blown out on the machine. To access this part on the duet, I believe the fuse is located in the front behind the kickplate which can be taken off by removing the screws on the bottom side of it. Once that is done the thermal fuse is located next to the thermistor on the exhaust of the machine just below the lint trap. On some models the fuse may be located in the back. If you get your model number and go to www.partselect.com you can get an illistrated blow out and locate the exact are the fuse is located.
May 18, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Disassemble kenmore 970c8810600 dryer
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else. If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed
There are 4 different designs that used on these dryers and each one has its own specific way to access the element, blower, fuses. etc In this FAQ I will describe each design and method to access for each one. ---------------Design 1: This design for this dryer has the heating components located in the front of the machine, which means to gain access you'll have to lift the top and remove the front. You can visually verify this specific type because the lint screen is located inside the dryer requiring you to open the door to gain access to it. As with any do itself repair, always unplug the machine before you start. Here's the method of access listed in numerical order. 1) Remove the lower kick plate by pressing in the two clips, one on each side located in between the upper and lower portion of the front In doing this you'll gain access to the element, located on the right hand side facing, the high limit and thermostat fuse located on the element, the cycling thermostat, located on the blower housing, and thermal fuse, located next to the cycling thermostat. In gas models the gas coils and ignitor may be located on the left hand side facing. If changing the belt, rollers or motor, continue to step two. 2) Lift the top by placing a flat head screwdriver in between the front and the top of the dryer and pry it upwards. In some cases there are two metal clips, one on the left and one on the right, that need to be pushed forward to lift the top up. 3) With the top up and the kickplate removed take the door springs off, one on each side, and remove the door by taking out the 4 screws one upper left and right, one lower left and right, off and don't forget to disconnect your door switch-----------------Design 2 : In this design the heating components are located in the rear of the machine. All you have to do is get behind the dryer, remove the 9 1/4" screws and remove the panel. The element eill on the right had side with the two fuses located on it, the cycle and thermal fuse will be on the lower left on the blower housing. To access the belt, rollers etc, remove the lint trap on top, take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off.--------------Design 3 : In this design the components are located in the front of the machine, but to access them you'll follow the method used in design 2 for accessing the belt, rollers, etc.take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off. The set up will be like design one.--------------- Note: The best way to determine if your dryer is desgin 2 or 3, remove lint trap and pop the top. When you've got this done, you'll be able to look in between the inside rear wall and the rear panel and see if the element, fuses atc are there. If not it will be design 3---------Design 4 : HE, HE2, Duet, etc the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed. From there you'll remove the kickplate in come cases by taking the 3 or 4 screws off located at the bottom of the kickplate. With that removed you will be able to remove the front, but only after you remmove the control panel. The In some cases the components will be located in the rear like the second design.
May 10, 2012 | Kenmore Dryers
Where is the thermal fuse
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct.
Apr 29, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do you check a thermal fuse on a Whirlpool duet dryer front loader?
These button thermal cutouts should pass an electrical current when cool. Therefore, use an ohm meter or a test lamp to check that. The meter should read zero or nearly zero, and the test lamp should light, to indicate continuity.
Nov 19, 2011 | Dryers
Will not start
The problem is likely a blown thermal fuse.Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Dec 18, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Dec 12, 2009 | Whirlpool Dryers
Whirlpool Duet Dryer stopped working
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Dec 27, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer won't start
hi thanks for the question theres a small thermal fuse located under the door behind the panel to get access remove front bottom panel 2 screws at bottom of panel and on the air duct to the left theres a small thermal fuse check it for continuity if bad replace thanks the appliance doc
Aug 20, 2008 | Kenmore 62872 Electric Dryer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
