Question about Digi 002 Rack FireWire-based Pro Tools LE External Sound System
Digi002 Rack My G5 computer is not able to locate the 002 hardware. Is there any solution here?
The 002 racks have a set of ribboncables coming off of the dc power harness. simply disconnect the ribbon cables use contact cleaner to clean the connection, and reconnect. I had the same problem and this fixed it
Posted on Mar 05, 2009
    Novelist:
    Champion:
  • 382 Answers
Reinstall the driver with the unit dissconnected. Check to make sure your version of OSX is stable with your current version of Protools, especially if youve done any software updates.
Keep me posted.
Posted on Nov 06, 2007
SOURCE:
How to install the drivers for digi 002 on windows 7
Here is the official AVID page regarding the digi 002 drivers: http://avid.force.com/pkb/articles/en_US/Download/Digi-002-003-Drivers
Feb 05, 2013 | Pro Tools Digidesign Digi002 Mixer Avid
Pls give me the download details of stadalone digi002 driver for windows xp64bit
Below is the link for your requested download
Link for driver download.
Tell me how it worked for you.
I am following up.
Regards.
Aug 09, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
Hi i have digi design rack 002 with pro tools le
Try the other port on the 002. If that doesnt work, I recommend trying the 002 on a computer that does have 400 to see if it will connect then.
If it doesnt, then you may have a couple blown firewire chips inside your 002. It happens, and can be fixed.
Jun 29, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
Turn digi 002 on and the mute light keeps stay on
I just had the same problem... It has to do with the connectors from the power harness. Found this on the internet and it did the trick for me...
It seems like it's only a matter of time before the digi002 (rack and non-rack) have this problem. You'll go to turn it on and the mute light turns on and nothing else. You don't hear the 3 clicks that you usually hear when turning it on. Your computer doesn't recognize it. Then you start swearing and promising to quit recording forever. After all that happens, you have 2 options:
1. call digidesign. they've been replacing the power harness (source of problem) for just about everyone, even if you're out of warranty and it's free (including the tech support over the phone). don't pay them anything. maybe shipping.
2. most people seem to have the same problem after a while after getting their new power harness. lots of people are saying it's not even the harness - just the connectors. so last night i had this problem and i opened up the top of the box and unplugged and plugged back in the little rubber-covered wires going from the power cord to the rest of the 002. turned it on. works fine. i may try to use some of that connector-cleaner from GC if it happens again.
so if you find this happening, don't panic. try the above. takes 5-10 minutes (only because of all of the screws)
Jan 26, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Macbook pro does not detect digi 002 rack
yeah i have an intel imac and had the same problem. I upgraded to pt le 7.4 and now pro tools recognizes the 002 rack and it works fine, but still the core audio manager does not recognize the hardware. It says in "use" when I first turn on the 002 rack, then it says not connected after about 20 seconds. I don't think this really matters though because I have beeen able to do everything fine without having the core audio managr recognizing the 002 rack. I hope that helps
Dec 04, 2008 | Computers & Internet
002 rack red light only
DSQRD here...
After disconnecting power source, I went back in and unhooked and rehooked the white plastic connector located at the front of the unit. It's in between the power switch and the mainframe and has about 6 wires through it. This time it worked and the 002 lit up. It's kinda humid in my studio and I think the connections film up easily. I plan to address that issue as well. It was a coincidence I guess that all this started the same time I hooked up the external drive. It through us off as to what had happened.
Good luck
Feb 23, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
Installing Pro tools LE 6.7 on G5
If this was already solved, well, this will help someone else. My guess is your new G5 came with 10.4 or 10.5 and you possibly tried to install LE 6.7 or earlier. This will not work on these OSs. If you have 6.7 you can upgrade to LE 6.9.1 for free and this will solve you problem. If you have LE 6.4 you are screwed and will have fork over $75 to Digidesign to upgrade to 6.9.1...or upgrade to 7.4, which is actually kind of worth it.
Feb 14, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
"Unable to locate" 002 Rack Unit - sometimes!
Please help this guy and me too. I had the same problem. I emailed digidesign but cant get a good answer. I hpe this shit is not broken. I just bought it 2 years ago.
Sep 10, 2006 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 Rack FireWire-based Pro Tools LE External Sound System Logo
290 people viewed this question
Top Digi Computers & Internet Experts
Alun Cox
Argospete
Argospete
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
