Question about Pix Cameras
Fujifilm jx200 battery door
Door of camera is not shutting completely
If the connections are tight and not loose, battery should not drain excessively. Gap in door should not drain batteries. Try gun wrapper over battery to improve connection if battery moves.
Jul 13, 2016 | Fujifilm Finepix Ax500 Digital Camera -...
How do I open the door to install battery
Slide the battery cover toward the front of the camera and it will swing open. See the illustrations on page 8 of the manual at http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/j/finepix_jz200_jz100series_manual_01.pdf
May 22, 2013 | Fuji Photo Film Co. Ltd Fujifilm FinePix...
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Dec 16, 2011 | FUJIFILM FinePix XP30 Digital Camera
Free download of a manual for Fujifilm Pinepix JX220
You can download the manual for the JX200 series here
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/j/finepix_jx200_manual_01.pdf
Regards,
katharsys_i
Mar 03, 2011 | Fuji Cameras
Fujifilm S1500 broken battery door
Yes, but you would most likely (don't quote me) have to send it back to the manufacture to get it fixed. That means $$$, is there a way for you to tape it on? You really only need the metal piece/plate touching the batteries.
Jul 26, 2009 | Pix FUJIFILM Fine S1500fd Digital Camera
Fujifilm finepix s700 is not turning on
OK
First check the battery door to make sure that it is closed properly. If you have a media door (the door which covers where the media cards are inserted) make sure that is closed properly. If this is the case then check that there is no plastic broken off. The doors contact with microswitches which allow the camera to turn on.
On the camera there is also a playback button. (green triangle) If you hold this and the camera turns on then your power switch is faulty.
Failing all of this then put some power into the camera via an adapter. If the camera turns on then it is likelly to be a battery fuse.
In all instances you will need to send the camera to be repaired at the fujifilm service centre. Web address below.
http://www.fujifilm.co.uk/technical/camera_repair/
Dec 17, 2008 | Fuji FinePix S700 Digital Camera
Canon jx200 check 5100 error from new
- DISCONNECT THE PRINTER OF THE POWER
- OPEN THE DOOR AND CONNECT TO POWER
- TURN ON
- AND YOU GO !!!
This works for me
Jul 08, 2008 | Office Equipment & Supplies
Cameras Logo
18 people viewed this question
Top Pix Cameras Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
Are you a Pix Camera Expert? Answer questions, earn points and help others
