Question about Garden
How to change oil filter on craftsman mid engine riding lawn mower
Mid engine 13.5 HP craftsman riding lawnmower model 536.270321
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
  • 138 Answers
SOURCE: Craftsman LT1000 ridign mower engine dies after 15 min-deadman on
There are several things that could be going on, but what you said in your description about the dead man switch in the seat may need your attention first. The switch it self could also be bad. After you rule this out the next thing I would check is the fuel shut off solenoid located on the carb when you turn the key on to run you should hear a click and feel it in the solenoid. After this you may have a fuel pump issue or a coil issue. but from what you I have described I believethe first 2 itmes I mentioned should fix your problem
Posted on Oct 09, 2009
  • 146 Answers
SOURCE: Oil leak on riding Craftsman LT2000 (Kohler)
Fortunately, the engine oil doesn't go through any rubber hoses, so they are mouse-proof. The oil probably leaked out through an engine seal. Oil on the engine surfaces would smoke when it gets hot. Check your oil level and top it up if necessary, before you run the engine again. The engine can run fine even with a slow oil leak; you just have to watch the oil level from time to time. The leak could be easy to fix - by tightening up a few bolts -- or expensive.
The gas runs through rubber hoses, though. If mice ate through that, I think you would have smelled the gasoline, and the engine wouldn't run for more than a few seconds. But if you see a severed hose, you should replace it. Take it off and bring it to a mower shop or auto supply shop, and buy something the same diameter. Inexpensive.
Hope this helped! If so, please rate my answer, thanks!
Posted on Jun 07, 2010
Testimonial: "Whew, you've eased my mind. I'll head out tomorrow and try your suggestions. I really appreciate your input and the fact that you are willing to respond! Thank you!"
SOURCE: How much oil does my craftsman riding mower hold? ...
4.5 pints with filter or 4 pints without
Posted on Sep 26, 2010
What kinda of oil do i use for my lawnmower
Two choices I'd recommend if you change your oil faithfully than you can use a SAE 30 weight oil. A lot of manufacturers will recommend using the newer version of oil that doesn't break down as quick where as a lawn mower motor runs at such high temperatures due to being an air cooled engine. Most auto supply stores or lawn and garden dealers will carry the longer life based oil, but personally I prefer to stay with what has worked for me for many years. Preventative maintenance , (Faithfully) for me means every spring. Good Luck
Jul 10, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Hi, what kind of oil can i put in my ridind lawnmower craftsman?
The domestic engines (Briggs, Tecumseh) take SAE 30 weight motor oil. The import engines (Honday, Kawasaki) usually take 10W30 motor oil. In either case, I recommend using a good quality name brand oil like Castrol, Pennzoil, etc. Most riding mower engine take about 48oz from a complete drain. If your engine has an external filter, it might require a few more ounces.
I hope this helps.
Aug 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Oil change
may not have one, need to change oil more frequently, ie. more than once a season like you most likely would for an engine with a filter
Jun 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro lawn mower
You may have overserviced the oil.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman ys 4500 lawn tractor change oil indicator won't go off
Being a reminder light it should reset itself after engine run hours increase from the programed reminder time
Jun 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
