Question about Singer 7422
One step button Hole V for Singer Sewing Machine
Well, I somehow managed to misplace my Manual for my Singer 7422, and I need to know how to use the 'One step ButtonHole' foot. I have an idea slightly how, but I'm not sure the process.
  • nancygdiamon Aug 15, 2008
    I have lost my manual for the singer 7422 and I need to know how to use the button hole
  • Anonymous Mar 25, 2014
    I lost the manual to my new Singer 6160 and dnt know how to make buttonholes. can you help me? do I need a special attachement?
  • 3 Answers
Hi, I had the same problem, but I finally found my manual. The solution is that you have to use the presser foot for buttonholes but the most important part is that you have to lower the buttonholer lever. It is located right next to the needle to the left. It is a metal lever with a little square white plastic end. You need to pull that down in order the the buttonhole feature to work. My button was too big for the buttonhole presser foot, so I had to use the regular presser foot, but hit the buttonhole lever with my had to make it go up or down.
Posted on Oct 28, 2008
  • 1 more comment
  • Lolalexander
    Lolalexander Oct 28, 2008
    Sorry I had a few typos on my last posting. These are the exact instructions from the Manual.
    1. Select one of buttonhole patterns.
    2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
    3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
    4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
    5. Carefully mark the position of buttonhole on your garment.
    6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
    7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
    8. While holding the top thread, start the machine.
    *Sewing will be completed automatically.
    9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
    I hope this helps.
  • Lolalexander
    I hope this helps.
  • flowerchild1953
    flowerchild1953 May 09, 2014
    Thank you for this information. My machine has just arived and I am testing all it's functions and got completely stuck despite reading manual a dozen times and watching a utube instruction. Then I discovered from above comments that I was not pulling down the button hole lever. Silly me!! so back to work and thank you for the help
SOURCE:
I have a Singer Confidence sewing machine trying to get button hole attchment to work, I get beeping, nothing moves,selected the button hole pattern, attached the foot what missing
Did you pull down the sizing lever on the sewing machine? Look at your manual, it will show you the lever that has to be pulled down for buttonholes. If, you have misplaced your manual, you can go on Singer's website www.singerco.com and under support you can download your FREE manual. Also go on www.youtube.com, put in Singer Confidence sewing machine and you will see some wonderful videos for your machine use. You have a very nice machine, btw..
Sep 08, 2017 | Singer Sewing Machines
I have a singer 7422 sewing machine which is made in canada. I want to use it in india. So, what type of step down converter do i need and how much watt.
Hello Gargi Sarkar
The power supply voltage in India is between 220 V and 240 V. Your machine will be ruined if you plug it directly into the power supply in India. There are two options:
1. Use a step down adaptor to 'reduce' the 220 - 240 V to 110V which is what your machine can handle. This may be more practical and economical AND you can use the step-down adaptor for other Canadian electronics.
2. Your sewing machine motor can be changed for a 220 - 240 V motor, but often other parts will need to be changed as well. Also more costly.
Happy Stitching
Sewingirl/
Feb 20, 2017 | Singer 7422
I want to do a button hole on my singer sewing machine model 7422 i've got the manual and i've followed what it say's but it only beeps when i pressed the pedal to start sewing i followed the instruction...
I do not have a fancy Brother machine. From what I understand, you just need to do a zig-zag stitch around the "rectangle" that will become the button hole.
You could forego whatever instructions they provide and just set your stitch width as appropriate and then move the stitch type to a thin (close together stitching) zig-zag, just shy of "satin stitch" (which is just sewing back and forth all in the same place, and therefore--useful for embroidery).
Sometimes easy does it can be the ONLY way to get things done. :) Sorry I don't know more about your specific issue but maybe the old school way will help.
Mar 03, 2014 | Singer 7422
For the Singer Advanced 7422 machine. I put on
have you got a buttonhole lever on the sewing machine that has to be pulled down first before starting the buttonhole?
Aug 29, 2013 | Singer 5050 Mechanical Sewing Machine
I am trying to rethread a bobbin for my new Singer Advance machine. I have misplaced my manual. Can you help by providing instructions?
If, you go to www.ifixmachines.com you can download your manual for $12.88 and receive a bonus parts list. That is the least expensive I have seen. Good luck
Oct 30, 2010 | Singer 7422
I have misplaced my manual for my sewing machine model # 7422. Where can I get another one?
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=653&option=com_virtuemart&Itemid=54
May 29, 2010 | Singer 7442 Mechanical Sewing Machine
One step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
May 15, 2009 | Singer 7422
Singer 7422 Logo
1,007 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
