Question about Garden
How to remove shaft from mandrel on mcculloch 300ex
Undone blade and pulley but shaft willnot come out of mandrel
  • 376 Answers
SOURCE: I had to get a new mandrel housing which goes
You have to remove the nut on top of the pulley. With the pulley off, the shaft will slide out the bottom with the blade. Don't forget when you put the pulley back on, the washer/spacer goes BETWEEN the pully and housing, NOT on top of the pulley. Dwain
Posted on Jun 08, 2009
  • 376 Answers
SOURCE: i am having problems stripping the mandrel shafts
Are you saying the pulley on top of the blade spindle is stripping out? If it has done it once and you did not replace the pulley and shaft, it will happen again. The shaft and the pulley are splined and if they gets loose, it will strip the splines from both. In other words, you have to replace the pulley and the shaft for it to work...and tighten them securely. If that doesn't answer your question, let me know. Dwain
Posted on Jun 15, 2009
  • 138 Answers
SOURCE: mandrel ruins pulley
there are only a couple of things that could be causing this: either the spacer [looks like a thick washer] is put on above the pulley [it goes UNDER the pulley], or the nut holding the pulley on is not being tightened enough
Posted on Aug 21, 2009
mowerman1857
  • 389 Answers
SOURCE: How can I un-bolt the Mandrel Pulley from the shaft?
If you have the deck removed from under the tractor you can try putting the blade back on tight if you have removed it and then use the blade to keep the mandrel shaft from turning. It takes quite a bit of torque to break the nut loose on the pulley so a socket and ratchet or breaker bar is the best thing to use. Other than that there is no "special" tool required
Posted on Sep 26, 2009
  • 9 Answers
SOURCE: how do i remove pully wheel to remove mandrel from
Think you're going at it from the wrong end, should be four bolts holding the whole assembly. Take off the blade and pull the rest up through the whole, leave the pulley on it. Don't buy new bearings, better off and cheaper to get a used one that works.
Posted on Oct 22, 2009
I replaed the blade drive mandrel and reattacheed the blade and the blade does not freelyturn t is so bound up tht I cannot turnit manually
okay check see if brakes is on the mower, not the tractor but the blades of the mower deck if not then take belt off of the new mandrel side and try turning blade by hand. should turn freely if not mandrel is bad but unlikely. sounds like you changed wrong side mandrel I presume you have 2 blades and mandrels. or when you installed it back on. the belt may be bound up between a guide and pulley just kind of look things over before a tear apart. and then do your tear apart one step at a time then check blade to see if it turns does not seem serious you may have put belt on wrong, I have done it my self. hope this helps major note do not do this with engine running cut you hand off in a flash.
Aug 13, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Pulley blade assembly /how to get it appart to change barrings
You will need to remove the pulley from the deck and using a mallet carefully knock the shaft out. There is another way that does not involve disassembly of the mandrel/spindle, you can purchase another mandrel/spindle for replacement. For me, I always break the mandrel/spindle before the bearings go out anyway.
I hope that this gets you going soon.
Jul 31, 2011 | Garden
Shaft problems
un hook l/h and r/h lift pins from both lift arms , remove front draft arm from front of deck ( it attaches under the muffler on the chassis )
discoonect the blade engage cable from arm if it uses this type or pop the deck belt off the electric pto if the tractor uses this type
you could just spin each spindle without the blade on ( but leave the top pulleys on ) if spindles bent you should see a wobble , if hard seeing it refit both blades and re-spin each spindle and check for quite a noticable variation in blade tracking when each blade is turned through a rev or two
remove deck , remove both mandrell pulleys from the top of thier shafts
remove both blades and use block of wood and knock the blade spindles out of their mandrells from the pulley side
here is website for parts
http://www.outdoordistributors.com/AYP/AYP_Main.html
just click on 917 the select 288280 from the list
it should show parts breakdown
cheers hope it helps
any problems let me know
paul
Aug 01, 2010 | Craftsman Professional 24 hp 42" Yard...
How do i remove pully wheel to remove mandrel from deck? once i get the mandrel off the deck how do i remove the shaft and barings to put them in the new mandrels? 54in deck sears craftsman lawn tractor...
Oct 22, 2009 | Craftsman Garden
Sep 26, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mandrel chews pulley
Are you sure the spindle is not bent and also are you balancing the blades when sharpening. Other then that make sure bolts are tight on the mandrel. With the deck off and standing up spin the blades and watch center of balde to see if something is bent. Also watch pulley on the other side to see if its bent.
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to remove mandrel shaft on husqvarna YTH2046 K riding mower
Remove nut on top of the pulley and the shaft will come out the bottom with blade attached.
Jul 03, 2009 | Husqvarna Garden
Jun 08, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
