Question about Troy-Bilt TB144 26cc 4-Cycle Gas-Powered Cultivator-Tiller with Edger
Oil leaking through the air filter on troy bilt cultivator
This is a TB146EC the oil is leaking out of the air filter at a high rate of speed it is not over full. Can't find any information in the operator's manual
  • 376 Answers
SOURCE: Just bought a 10 hp troy bilt chipper used. When
As LeeatCSEb said, It's your float needle and seat not shutting off the flow of gas when your carb bowl is full. Have your needle and seat replaced. Dwain
Posted on May 18, 2009
  • 9 Answers
SOURCE: engine stalls when engaging cultivator tines
im 99 percent sure all you have to do is get the carburator cleaned out.
Posted on Jun 28, 2009
  • 5 Answers
SOURCE: model 47321 troy-bilt chipper 10hp fuel
Check the oil level. If the oil is low, the chipper will not continue running.
Posted on Aug 22, 2009
SOURCE: Looking for a user/owner manual for a Troy-Bilt chipper/vac?
HI believe that we have a 47287 8 hp chipper/vac where would i find Model on chipper vac
Posted on Dec 12, 2009
Testimonial: "I purchased a manual from the gentleman in Minnesota..frederick7153@comcast.net He'll fix you .. first rate quality, better than new !"
hunter19_46m
  • 7482 Answers
SOURCE: troy bilt 4 stroke trimmer tb575ec won't run at high rpms. it starts, but dies when throttled up. only 2 months old, added fresh gas, checked oil, did not see adjustment screws on carb?
Hi jim gabriel
Sounds like you have dirt/debris in your caburetor jets,fuel passages
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 13, 2012
How much oil should be in troy built cultivator
Check the dip stick on level ground. Clean it off and reinsert it. The dipstick has the mark for correct amount. If you see it coating whole stick, it is way overfilled,
If not.......Your filter can possibly be plugged and the heat in the crankcase is creating pressure that pumps some of the oil out the filter. Get a new filter or clean it out. Might need oil change to get rid of dirt or sludge
Feb 27, 2015 | Troy-Bilt Garden
How to replace gas lines on the tb146ec cultivator.
Hi Robert:
Sounds like a matter of removing the old lines and installing new ones.
Work safe! Drain fuel from tank first.
May 03, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
I am having a hard time getting my carburetor adjusted for my Troy Bilt 2 cycle tiller
First you need to repair the fuel inlet properly. You likely have an air leak the way it is now. You can get a replacement inlet elbow at your local parts shop. Tecumpseh and briggs are a bit different but look very similar so be sure what you have before you go. grab hold of the brass with channel locks or vice grips and pull straight out to remove the old one. Put a dab of oil on the new one, align the way you want it to face and press in firmly. Do not twist or it will break again.
Once the inlet is repaired properly then you can adjust the carb. The low speed jet is the one closest to the motor. The initial settings are 1 and a half turns out for both low and high.
Sep 19, 2012 | Troy-Bilt Garden
Why would oil leak out of filter on a troybjilt 146ec tiller I
a bad filter filters not tight filter is not for that engine
Mar 28, 2012 | Troy-Bilt Garden
Troy-bilt cultivator 26cc gas/oil separate engine spewing oil out through filter when running...there is a hose from the oil reservoir straight into the back of the filter...as the engine revs it literally...
Hi, Check the oil reservoir breather that it's not plugged up. The oil should be returning back to the reservoir not going to the filter. That tells me that there is air being pumped into the engine (oil).
The piston rings could be broken or the carberator needs to be readjusted.
Open the air screw abit more on carb. Then see what happens. Good luck.
Jul 30, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
Engine oil coming out of air filter
If the tiller was lying on it`s side the oil would flow into the carb. and filter.
You will have to remove the carb. and wash it out. Check there is not too much oil in the engine.
May 20, 2010 | Troy-Bilt Pony Garden Tiller
Oli spils when lawn mover starts
Check your oil level in the engine, normally if oil starts coming out of the air filter, it means you have too much oil in the crankcase. Drain your crankcase to make it the right level, be sure to check you oil level in the engine on level ground. I hope this helped, Good Luck Please rate me, Thanks
Dec 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy built cultivator will only idle 26cc 5yrs old
Problably not sucking air, but not getting enough air. Does your cultivator use gas/oil mix or straight gas? If it is a gas/oil mix the muffler is probably stopped up with carbon and cutting off the air flow. Try removing the muffler and see if it runs better.
Jun 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy-Bilt TB144 26cc 4-Cycle Gas-Powered Cultivator-Tiller with Edger Logo
698 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
