Question about Cuisinart Coffee Makers & Espresso Machines
Whats error code erl - Cuisinart Coffee Makers & Espresso Machines
My cuisinart cbc 1600 wont stay on its shows erl on the screen and shuts off .. what is this problem and what can do to fix it
There's a three year warranty on this unit. If it's less that 3-years old, contact Cuisinart for a repair or replacement.
Jun 04, 2016 | Cuisinart Coffee Makers & Espresso...
Where is the. 02 sensor fuse for a 2003 saturn
What model Saturn ? For the heater circuit ? Check for Fuse ERLS 10 amp in under hood fuse box. This is just for heater circuit ! the O2 sensing part gets power from the PCM /ECM
Dec 06, 2015 | Saturn Cars & Trucks
When i plugged it up, it's displaying the letters "ErL" what does this mean
This is some Kind of Error Code.
The Machine is doing some diagnostics, and found a serious problem.
Contact Cuisinart Customer Service at 1-800-726-0190.
Nov 24, 2015 | Cuisinart Dcc-2800 Coffee Maker, 14 Cup...
HOW DO I FIX THE MESSAGE ERL = B14B ERR=005 ON DENDO PDE
What problem(s) are you experiencing with the drive? Is it visible in Device Manager and My Computer?
Jun 29, 2014 | PDE Technology Computers & Internet
Where is the erls fuse on my 96 chevy cavalier and does that control my 2-3 shift solenoid?
The ERLS fuse does power the solenoid, and the computer grounds it, making it work. Its located in the fuse box. which is on the left end of the dash board.
Nov 20, 2009 | 1996 Chevrolet Cavalier
Getting P0758D Code when i scan the car what code is this?
CODE PO758 IS A/T 2 - 3 SHIFT SOLENOID CIRCUIT 4T40 -E OR 4T45 -E CONDITIONS. THE 2 - 3 SHIFT SOLENOID IS DAMAGED OR HAS FAILED.OR CHECK THE ERLS FUSE.
Nov 19, 2009 | 1996 Chevrolet Cavalier
Pulled a code and can't find out what it means
Code 27 and 28 refer to the quad driver circuits in the ecm. These control the grounds for various outputs.
Code 27 is for tcc, canister purge, and egr soleniods. Code 28 refers to fan relay, a/c compressor relay and cruise stepper motor. The canister purge, egr and compressor relay, brake switch and tcc solenoid are all fed by the erls fuse which is probably blown. Check the fuse if it is blown you will have to check these components for a short or a short or open in the wiring. If it is ok check for battery voltage on the pink wire on these solenoids.
Jul 25, 2008 | 1995 Chevrolet Cavalier
Coffee Makers & Espresso Machines Logo
50 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
