Question about Air Tools & Compressors
Problem with LG fridge Model GR-382R with hot compressor
Does this sound like the compressor has run out of gas, because it is hot
3 Suggested Answers
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
SOURCE: i have electrocool LG MOdel# GR-382R ser#
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
Posted on Jan 07, 2011
LG GR-B206GTQA Fridge Freezer ER CF Error Code
The fan is almost certainly run by a sensor in the condenser. If it doesn't get hot enough, the fan doesn't run. Sounds like short of gas. Try wiring the fan to the compressor live and see if it runs all the time then.
Apr 18, 2014 | Refrigerators
LG GR-S512GCA NOT COOLING
check and see if compressor is kicking on and off after a few sec if it is you might try a hard start on the compressor its a little switch that goes on the compressor where the wires go cost around thirty dollars be worth a try before going out and buying a new fridge
Jan 27, 2014 | Refrigerators
I have a LG refrigerator model no. LFX25960ST that stopped working. All my meats in the freezer defrosted and the upper fridge is also warmed. I can hear the fan running. I unplugged it and plugged back...
it is not a great idea turning a fridge off and back on straight away. It will overload the compressor and cause it to trip out. I would suggest that the starter relay has failed on the compressor but if the fridge has been left to cycle on and off too many times, it will damage the compressor. Turn it off and get a fridge tech to look at it and confirm the fault.
Jan 28, 2018 | LG LFX25960ST Stainless Steel French Door...
Sounds like the fridge is running but it and the freezer are not cold
if compressor running and no cooling, sounds like a gas problem. if compressor is v hot to touch as in you couldnt hold your hand on it def gas.
unless under any kind of warenty i would recomend a new fridge
Sep 23, 2010 | Refrigerators
I HAVE AN LG FRIDGE FREEZER GR-349SNQF. THE FRIDGE IS NOT GETTING COLD
Shut off fridge for about few hours so as to defrost off totally. then switch on. If the cooling returns perfectly then you must check on the auto timer, the thermostat, the heater.
However if there is no cooling then the gas is down or the compressor pumping pressure is low ... the compressor is faulty in its mechanics.
Now you need to deccide before moving further. the cost of a heavy repair to an exchange for an new fridge with warranty/new technology/power saving features.
Decide on this advice. Find this helpful?
Aug 20, 2010 | LG Refrigerators
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
Thanks.
Jun 22, 2009 | LG Refrigerators
Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Feb 28, 2008 | Refrigerators
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Air Tools & Compressors Logo
24 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
