Question about Lorex Eco 16channel H264 Security Dvr W 16 Cameras
Lorex dvr does not seem to be communicating with Panasonic TV
Have checked all connections and cables as well as cameras yet I do not receive any images from system on the TV. I also am not able to access any setup/menus on screen. It appears that DVR and TV are not communicating. I have checked HDMI cable(tried several); HDMI connections (HDMI 1; HDMI2 and HDMI 3). When I turn TV monitor on with correct input setting and then power up the DVR, the DVR power LED comes on followed by the HDD LED, several audible beeps and the HDD starts flashing but nothing appears on the monitor. I have tried to access the menus using the remote and nothing happens. I have checked and rechecked the cameras all the connections and all the cables with no apparent results.
3 Suggested Answers
  • 11 Answers
SOURCE: i have 2 lorex dvr's. both need web access, can it be done
there are a few ways to accomplish this. one way is you will need more then one static ip. one static ip for each machine, you will then be hitting them on the same port but different ip's. the simplest way is to change the web port setting in the lorex dvr from 80 to something else in the second machine.
Posted on Dec 29, 2009
  • 14 Answers
SOURCE: system will not connect
check the comm cable between the computer and the device make sure that all settings are correct like address, baud rate, comm port connection, and their may be a setting that controls how long the device will attempt to connect this needs to be disabled.
Posted on Mar 14, 2010
Why can't I record on my DVR?
Check all your connections and configuration between decoder to DVR and TV. I find it is more practical to use the DMI connectors for this purpose. Between my LG TV, LG DVR, LG Blue Ray Player and Decoder I use 3 DMI connector cables. Ideal for me because my TV has 3 DMI points, I just connect each of 3 items to TV via a DMI cable. Now connect decoder to DVR via video-audio cable (red-white-blue). This setup allows each unit to be used individually (i.e. tv viewing, recording, blue ray playing and when recording live TV the TV can be switched off while recording. Just remember to select the appropriate DMI connected unit on your TV remote (on "input" button).
Feb 16, 2016 | Panasonic Televison & Video
Lhv1000 DVR. Why doesn't it display anything?
Check out the video unboxing and trial setup at Lorex 8 security Camera.
Follow the hookup guide.
Make sure you have setup the mobile/Pc connectivity also.
Refer to the user manual online at https://www.lorextechnology.com/downloads/security-dvr/LHV1000/LHV1000_SERIES_MANUAL_EN_R2.pdf
Have you connected the usb mouse; TV or monitor.
Note
  • For cable runs above 300ft / 92m (option 3), you must connect the power adapter directly to the cam- era, rather than at the end of the extension cable (see diagram in page 6).
  • Indicators that your cable run may be too long:
    • Video is permanently black & white (even during day time).
    • Video is unclear, soft, or distorted.
May 09, 2015 | Lorex Home Security
Lorex eco 130 can not get to menu, screen shows Lorex page
There should be a paper clip size hole somewhere on the back of the unit. If you depress the button in there it should be the reset. The problems sounds to me more of a hard drive issue though.
Jan 17, 2015 | Lorex ECO 16Channel Security DVR with 16...
I purchased a system from Lorex model # LHV08C02
Lorex used standard BNC and provides Siamese cables for all their DVR systems; like this one.. If you want to use your own, use 75 Ohm RG-59 or RG-58 with compatible connectors. If using premade cables, use BNC female to female. Power is separate and is provided by the 'wall wart' style power adapter.
Sep 29, 2014 | Home Security
Lorex troubleshooting
The most common reason for loss of camera remote video is an intermittent cable connection between camera and DVR. Try monitoring with a VGA monitor, or TV with analog VGA input also to see if that is the case. Gently move the cables around that run from the cameras to the DVR while observing the multiple cameras showing on the monitor. Some remote viewing software has trouble restoring camera assignments after brief loss of camera signal.
Sep 28, 2017 | Home Security
Does the lorex dvr support my MAC os on my pc
Hi Kavya,
Which model of Lorex DVR are you using? Currently, only some of our security DVRs are compatible with Mac OS X (via Safari). Our line of Edge and EDGE+ DVRs (LH300 Series) are Mac compatible and offer full remote viewing, playback, backup, and setup using Safari.
Please give us a call at 1-888-42-LOREX(56739) or visit us online at www.lorextechnology.com
Cheers, Lorex Support Team
Nov 11, 2010 | Lorex (L3501090)
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Panasonic dvr replay only shows in black in white
Bad cable connection, change cables, change splitter, go to RCA input.
Apr 15, 2009 | Panasonic PV-HS2000 Showstopper 30-Hours...
Lorex Eco 16channel H264 Security Dvr W 16 Cameras Logo
61 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
