Question about Garmin GPSMAP 545s GPS Receiver
Locating satellite system take a long time to locate satellite and until it does i'm stuck with kansas on the chart
  • Anonymous Jan 09, 2008
    gps545s fails to navigate ie receive satellite
  • 2,335 Answers
Initialization time has been greatly reduced with newer system software upgrade for the Garmin GPSMAP 545s. Get your system software upgrade here.
I hope that helps.
Posted on Jan 31, 2010
SOURCE:
Can not acquiring sateilites,and always start in kansas.dDid reset,and a hard reset.Samething.
How long did you leave it out in full view of satellites? In some cases, when the unit is new, you might have to wait 20-30 minutes for it to get an initial connection and to download the location info, etc to the unit. The location reads Kansas because that's where Garmin's head office is located so this is the default location.
If this solution solves your problem, please come back and rate our answer to your problem. Thank you.
Dec 27, 2010 | GPS
Can't get out of Kansas location --- can't locate satellites
Have you taken it outside to see if it needs better skyview to get a lock. I also suggest force feeding it the firmware again. You can use Garmin Webupdater to update the unit. It would of updated when you did the map update install but a file may of been corrupted.
Jul 11, 2010 | Garmin nuvi 255W GPS Receiver
The unit comes on, but it says that the GPS is turned off. It is stuck in Kansas.
Kansas is the default location when the unit comes from the factory or when a factory reset has been made. You haven't mentioned the model you have. Have you opened the antenna and let it acquire a satellite lock? Without a lock it has no way to know where you are.
Sep 15, 2008 | Garmin GPS
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
No signal
You will have to leave the unit out in the open so it can 'see' the satellites. It might need from 20-30 minutes to acclimatize itself to the new location. It is set at Kansas because that's where the manufacturer is, so that is the last recorded satellite signal.
Apr 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Can't change location-appears as if still in Kansas despite downloads
You need to go outside and turn on the Garmin until it has acquired a satellite lock (15-20 minutes). Kansas is the default location (Garmin Headquarters). Once you have acquire satellites, the Garmin will remember the last position as the starting position when the power is turned off. You know you have acquire a satellite lock once "Ready to Navigate" appears on the top of the screen.
Jan 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Location says I'm in Kansas
I got stuck in Kansas also. But, now I'm not in Kansas anymore! Are you trying to set your Garmin up indoors? That was my first problem. Go outdoors and try it. I did that and Toto and I were still in Kansas. SO, I pluged it inot my cigarette lighter and drove down my driveway. It took a few minutes for Garmin to locate a satalite, but once it did I was all set. No problems since, hope it works for you. I really enjoy using my Garmin. I'm one who ofter ends up on the road less traveled so, Garmin has come to my rescue a few times already. Have fun and say hello to the Wizard of Oz for me!
Christine
Dec 25, 2007 | Garmin StreetPilot c340 GPS Receiver
GARMIN BASICS FOR THE ELECTRONICALLY CHALLENGED
first turn it on and let the unit acquire satellites to find your home state. Then you can set up your address as your "home location". When I first set it up, I was able to pick up the satellites in my bedroom (scary....)...everything worked just fine.
Nov 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Getting started
Take the unit outside, so it knows where it is (you cannot tell it you want it to go from a location to another without being at one of the locations). Once the unit has a satellite fix, press Where To? Then press Address. When West Virginia and Spell State come up, press Spell State. Enter Florida (or start to, until the unit pulls it up, then press it). Then press Spell City, and enter Crystal River, then the house number and street name or number. Press Go! and you are on your way.
Nov 16, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin 350 Problem
Take it outside and turn it on.  Within a couple of minutes it should locate the satellite and tell you where you are.
Oct 06, 2007 | Garmin nuvi 350 GPS Receiver
Garmin GPSMAP 545s GPS Receiver Logo
171 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
