Question about Frigidaire Gallery FGHB2844LF 27.8 cu. ft. French Door Refrigerator with 4 SpillSafe Sliding Glass Shelves, 2 Clear Full-Width Humidity Crispers, External Ice/Water Dispenser, Ramp-Up Lighting and Self-Closing Pull-Out Freezer Drawer: Stainless Steel
ICE DISPENSER NO OPERATION
I am having a problem with this icemaker dispenser..It will not dispense. I was inclined to replace the module 242074204 but then it worked a couple times. Then it stopped again. I removed the cover and and gained access to the Assy. I was able to get it to work as long I hit the dispenser arm and operated the solenoid assy at the same time, it worked every time. can anyone tell me what is going on here..? Could I possibly have a bad main control board. The chute flap would open and close quickly and no dispenser motor. can anyone help.. Thanks Bob H
5 Suggested Answers
duby1990
  • 370 Answers
SOURCE: Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Posted on Nov 19, 2008
SOURCE: Freezer not freezing, and leaking
If this unit has an ice maker and you noticed water leaking into the refigerator, I had a similar problem. The water turn off valve for the ice maker had a small piece of sand or grit lodged in it and stopped the valve from closing properly. So it could not turn of completely and the valve became increasingly more sloppy as the piece of sand was wedged in further. The solution was to replace the samll valve. An easy job for someone a bit handy.
If the water has frozen in the bottom of the freezer compartment the colliing port for the cold air may also be affected. Don't chip the ice out of the bottom, defrost it with pans of hot water.
Hope this helps
Posted on May 03, 2009
  • 358 Answers
SOURCE: No water to ice maker. Water dispenser works fine.
The dual water valve is not working or is leaking and water freezes up in the ice maker filling tube and when it needs water won't go through.
Posted on Aug 14, 2009
Testimonial: "Good advice. It turns out the dual water valve was faulty. Thanks! "
  • 401 Answers
SOURCE: Water has been leaking into my ice bin and causing
This sounds like the water solenoid is seeping and needs replaced.
Posted on Feb 14, 2010
Frigidaire is not dispensing ice
Good Afternoon, thank you for your inquiry!
I see you are having trouble with your Frigidaire refrigerator dispenser not dispensing ice. Do you hear the auger motor running when calling for ice? If you do not, the dispenser may be jammed or the refrigerator has a faulty auger motor. I suggest try clearing any ice that is blocking the ice chute, removing any frozen ice or obstructions, verifying that the water valve or fill tube is not frozen. If any proves to be ineffective contact a professional to move forward accurately.
Best regards! - Z
Jul 11, 2014 | Frigidaire Freezers
Ice wont come out of automatic dispenser
If there is frozen ice in the icemaker tray then the heater element to slightly warm the tray for ice ejection is not working. If there is nada in the icemaker tray then water is not getting to unit - check water solenoid or the water line going to unit.
Nov 20, 2013 | Freezers
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
LG LRSC26923TT, water dispenser not working
I have a LG GRP207TUJA side by side freezer, which has a water,ice,crushed ice dispenser. There is a button to select which mode of dispenser. The freezer just appears to be cycling through all the selections all by itself and make the bleeping noise as it moves from one selection to another...any ideas
Sep 15, 2009 | Freezers
Why is there water in the ice bucket of my ice maker? It is a GE side by side, but without the dispenser in the door.
hello, how are you, if there is water in your ice bucket, it seems as though when your icemaker sends a signal to water valve to give water, your water valve is sending too much water into icemaker, the solution would be to replace water valve which is behind the refrigerator at the bottom. it should be blue in color which clear plastic tubing connected to it. This happens when the water valve solenoid doesnt close completely.
Sep 13, 2009 | GE Freezers
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer is not making ice
PULL THE FRONT COVER OFF OF THE ICE MAKER AND CHECK THE PLASTIC GEAR ON THE FRONT OF THE CONTROL. THE CENTER OF THE GEAR HAS TWO PLASTIC TABS THAT HOLD THE GEAR IN PLACE. IF ONE OF THE TABS IS BROKEN OR MISSING, THE CONTROL OR THE WHOLE ICE MAKER NEED TO BE REPLACED.
CHECK THE ICEMAKER TO SEE IF THERE IS WATER OR ICE IN THE MOULD. IF NO WATER OR ICE, THE FILL TUBE IN THE BACK WALL MAY BE FROZEN OFF. REMOVE THE FILL TUBE AND CLEAR IT OF ANY OBSTRUCTION. YOU CAN ALSO USE A HAIR DRYER TO MELT OUT ANY ICE FROM THE FILL TUBE. THE OTHER POSSIBLITY IS A BAD WATER VALVE. THE WATER VALVE HAS TWO OUTPUTS, ONE FOR THE DISPENSER AND ANOTHER FOR THE ICE MAKER.
Mar 31, 2008 | Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Frigidaire Gallery FGHB2844LF 27.8 cu. ft. French Door Refrigerator with 4 SpillSafe Sliding Glass Shelves, 2 Clear Full-Width Humidity Crispers, External Ice/Water Dispenser, Ramp-Up Lighting and Self-Closing Pull-Out Freezer Drawer: Stainless Steel Logo
94 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
