Need to replace the part yhat the water hose connects to.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number?
Posted on Jul 28, 2013
How do i change a thermostat in a 1996 mercury grand marquis
Hi, Welcome to FixYa.com my name is Shawn and I will be answering your question.
  1. Partially drain the engine cooling system so that the engine coolant level is below the water thermostat (8575).
  2. Disconnect the upper radiator hose (8260) from the water hose connection (8592).
  3. Remove the two water outlet connection retaining bolts.
  4. Remove the water hose connection gasket (8255) and water thermostat from the intake manifold (9424). Inspect water hose connection gasket for damage and replace if necessary.
Installation
  1. Install the water thermostat, water hose connection gasket and water hose connection as shown.
  2. I hope my assistance helped you and resolved your concern, if you need further assistance please ask.
Aug 07, 2011 | 1996 Mercury Grand Marquis
Tip
How to troubleshoot water leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Check the lid seal. If faulty, replace with a new gasket.
- Check the hoses at faucet connections. Tighten connections or replace hoses.
- Check the hoses at water valve connections. Tighten connections or replace hoses.
- Check the drain hoses. Tighten connections or replace hoses.
- Check the inlet nozzles. Tighten connections or replace nozzles.
- Check the splash guard. Tighten connections or replace.
- Check any plastic valve. Tighten connections or replace.
- Check the outlet hose to drain. Tighten connections or replace hose.
- Check the water pump, using the procedures that follow.
on Jan 16, 2010 | Washing Machines
Washing machine flashes and beeps E70
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Frigidaire Washing Machines
I have a ge washer wpsr3120w0aa that leaks water when rinsing
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Troubleshooting Water Leaks
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 29, 2009 | Washing Machines
Old admiral clothes washer leaks at front
Aug 25, 2009 | Maytag PAV2300 Top Load Washer
When I connect the water hose to the pressure washer and turn on the water, the hose pops off.
Either the hose connection or the pump connection threads are stripped and will need to be replaced.
Aug 24, 2009 | Black & Decker Garden
The water does not drain out. Water in tub bottom
hi Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Sep 13, 2008 | Amana Dishwashers
Water pouring out from soap tray !!!
hi Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Sep 13, 2008 | Washing Machines
Worthwhile to repair?
Hi thanks for the question The problem yhat you have is with the lid switch or the striker .the striker is located on the lid top right corner . If the striker is there then replace the lid switch Thanks for the question The appliance doc
Sep 12, 2008 | Kenmore Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
