Question about Boating
Fuse box for 1994 stingray
Need to check bilge pump fuse
  • 6 Answers
SOURCE: keeps blowing 15a efi fuse 1991 toyota pickup 2.2 re
there's a short somewhere causing that amperage to go up
Posted on Dec 13, 2008
SOURCE: jeep fuse box
the 2nd box is to the left of the brake pedal mounted to the fire wall.... I NEED A DIAGRAM!!
Posted on Jan 17, 2009
Fleetw00d
  • 31 Answers
SOURCE: windsheld wiper motor fuse? for 93 accord
10 amp fuse No. 5, middle of the 2nd row from the bottom in the under dash fuse box.
Posted on Jan 27, 2009
  • 3 Answers
SOURCE: need under hood fuse box diagram for 1994 ford f150
Your radio fuse is not under the hood. It is in the dash panel on the left of the steering column. Y have to have two hots one constant for the memoty and one accessory that powers on the unit when your ignition is engaged. All you need is a test light to find the constant when the truck is off and the accessory that comes on with the key. There may also be an inline fuse in the dash that is blown. It would most likely be on the memory hotwire.
Posted on Apr 19, 2009
c17hydro
  • 2984 Answers
SOURCE: Need Jeep Fuse Box Diagram
I'll post all 3 and you can decide which style you have:
Pic 1---
Posted on Jun 19, 2009
Bilge pump on 1996 nitro bass boat inop
Check to make sure the fuse is good and you have power going to the switch and then to the wires (brown for positive and black for negative) in the bilge area using a 12 volt tester. If you have power to the brown wire while grounded to the black wire then the pump will need to be cleaned, have the impeller replaced or replace the pump. The pump is located in the rear compartment attached to a board mounted to the inside bottom of the boat at the center near the transom.
Feb 12, 2013 | Nitro Boating
Fuse box diagram for a 1994 Chevy Cavalier 2.2 litter
The Fuel Pump Relay is located: Under hood, passenger side, rear side of strut tower, mounted on fenderwell
Sep 12, 2012 | 1994 Chevrolet Cavalier
Location of fuel pump relay 1994 toyota corolla
The fuel pump relay is located in the fuse box drivers side of fuse box
Jan 26, 2012 | 1994 Toyota Corolla
Pump is flowing at 1/3 capacity. I replaced the fuse after it blew not it runs buy very slow....I replaced it with the required fuse
the fuse is only a circuit protecter, it will not cause your problem. have you tried replacing filter? check voltage at pump for correct volts. my system has 2 wires, 1 is low speed, 1 is high speed.
Jul 18, 2011 | Attwood Tsunami Cartridge Pumps Tsunami...
I have a Yamaha FX Cruiser HO (2010). The jet ski died in the water on me last week. I determined it to be a fuse. Replaced the fuse with the extra one and it burned out again. Any suggestions?
i have a 08 yamaha fx sho it keeps on freezing up in the water and dying of, i was almost 10 miles into the ocean and had to be towed by one of my fellow riders. whats causing this problem?
Jul 16, 2011 | Yamaha 12V Air Pump
Looking for location of fuel pump relay switch on a 1994 Honda Accord LX
Hi!!
Check for a 15A Fuse labeled FUEL PUMP on the cabin Fuse Box located in the front seating area, driver side, under dash, behind kick panel.
The diagram shows the Main PCM relay controlling the Fuel Pump, but it wont hurt to check the cabin fuse box under hood, passenger side, rear side of strut tower, mounted in fuse/relay box on firewall
Don't forget to rate this post, Good Luck!!!
Jul 24, 2010 | 1994 Honda Accord
I'm trying to wire a 12v bilge manual pump to a
You run your hot wire to the switch (brown) and black wire to the pump (+ve connection). Then from the pump run another wire to the negative terminal of your battery. I used to use a toggle switch on mine, but I do not use a starter motor, still all the lights, radio and echo sounder are connected to it (via a junction box). The only item I fuse is my echo sounder.
Feb 03, 2010 | Boating
Bass tracker fuse descriptions
I was trained at a tracker dealership and that is one of their faults. The best way to find the fuse for the bilge pump is to look on the back of the bilge switch and trace a wire to the fuse panel. Most of the time they are color coordinated so you can match fairly easy without trying to manually probe for the wire.
Jun 10, 2009 | Boating
Fuse for fuel pump cant find
there is no fuse, there's a relay for the fuel pump. IE,, "the main relay", under the drivers side dash.
May 23, 2009 | 1994 Honda Prelude
Boating Logo
51 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
