Question about LG Flatron L3000A 30" LCD Monitor
LG 32" LCD Flatron
I have colored lines about every 4" on my screen. Can this be fixed?
4 Suggested Answers
  • 2985 Answers
SOURCE: LG Flatron LCD Power Saving Mode
Well thats seems tricky does it not come on at all when you boot the computer. If the screen is working then it should work to display the Start up screen. If it does then keep pressing Delete until the BIOS comes up- then search the pages for power saving and slect to OFF
Posted on May 26, 2007
  • 1314 Answers
SOURCE: HELP PLEASE LG Flatron w1952tq with blue line
If you just bought it and only used it one day, I would take it back for a replacement. Sure, you could fix it but if something went wrong on day one I'd be wary. Besdies, it would save you the hassle.
Posted on Jun 14, 2008
SOURCE: LG Flatron Monitor-adjust height and color,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Posted on Apr 12, 2009
  • 173 Answers
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Posted on Jun 13, 2009
0 characters
1 Points
Hi my LG w1934s LCD monitor suddenly not working it screen is full with color lines even I disconnect the VGA cable from the system unit the screen is not change the color lines are as it is what can I do...
That have not simple solution better take it to a tv repair shop, you already disconnect the data cable and discard the possibility of computer problem.
The Monitor must have in the menu a reset configuration option but I doubt it will help, its time to get it to a repair shop.
Mar 17, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
Omi have lg flatron 1941s lcd monitor its OSD locked how to solve it
i have a problem with my lcd a small area is permanently black a scratch like lines less than 4 mm X3 mm size
Sep 17, 2010 | LG Flatron L1515S 15" LCD Monitor
Color problem
LCD Screen problem if your LCD in under warrnaty so in that case LG provide Free services and they change your LCD Screen please contect LG Services station.
May 11, 2010 | LG 22" FLATRON LCD Monitor
I am using the LG Flatron L1715S 17" LCD Monitor as an external monitor for my lap top as the screen on my lap top is toast. What I cant figure out is how to size the screen to fit the proper dimensions of...
The FLATRON L1715S color LCD monitor with auto-synchronous support, plus it is PC and MAC compatible, has features like simple one button auto setup and is VESA DDC2B, DDC1, Plug and Play compatible.
use the 'Auto' adjust button on ur lcd..
howevr, if u want to configure using win xp/vista..right click on ur desktop->properties->settings->increase the 'screen resolution' to minimum: 640x350 or standard: 1152x864 or maximum: 1280x1024 @ 75Hz..
best is to seek professional advice of ur system admin/vendor....
Nov 05, 2009 | LG Flatron L1715S 17" LCD Monitor
Colored lines down the right side of monitor.
It seems that the lcd screen was damaged you mentioned something fell on it and damaged the lcd. You would need to replace.
Feb 12, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My monitor goes black and does not come on to i turn the powe off
Dear Sir/Madam,
Reinstall the monitor drivers and right click the desktop go to Display properties->Settings->Check the Screen Resolution and select 32 bit color check the screen resolution is 1024X768 if it is not listed there will be the problem with driver software.
Nov 26, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
Foggy screen
get some fogoff at your local hardware store
Dec 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Black line across my screen
hope your flatron is under wtty, get it checked before it is too late. It is a hardware problem which you cannot fix by yourselves.
Sep 29, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L3000A 30" LCD Monitor Logo
24 people viewed this question
Top LG Computer Monitors Experts
Lawrence Oravetz
Level 1 Expert
Are you a LG Computer Monitor Expert? Answer questions, earn points and help others
