Question about Garden
Toro belt diagrams routing 44 inch 30144 - Garden
old marine
  • 1992 Answers
SOURCE: need routing diagram for 2000 lincoln town car serpentine belt
There's a diagram at this link.
Posted on May 11, 2009
SOURCE: belt routing diagram 98 zx2 2.0
1) Start with the alternator.
2) Forward to the smooth idler
3) Forward to power steering
4) Down to A/C compressor
5) Back to crank pulley
6) Forward around tensioner
7) Back glancing off of water pump
8) Back glancing off of ribbed idler
9) Up around alternator (where you started)
Posted on Sep 11, 2009
bschilz
  • 2049 Answers
SOURCE: 2006 Dodge diesel belt routing diagram
Here's a link to the diagram you need...
http://www.gates.com/common/part_locator/view_diagram.cfm?id=S8023
Posted on Sep 23, 2009
Testimonial: "Awesome! thank you so much for the quick response!"
  • 7353 Answers
SOURCE: 1999 ford Taurus serpentine belt routing diagram
http://www.gates.com/common/part_locator/view_diagram.cfm?id=S7021
Posted on Nov 10, 2009
  • 1757 Answers
SOURCE: Need serpentine belt routing diagram for 1994 Dodge grand caravan
3.3L?
Looking at the engine from front (right side of the Van): Stating at the Top, Going Left to Right and Clockwise:
Over the Alternator
To under the Idle Pulley,
To Over the AC Compressor.
To the Left Side of the Water Pump.
To the Right side and Under the Crankshaft Pulley
To the Right side and Over and Down the Tensioner
To Under the Power Steering Pump
And Back up-to the Left side of the Alternator.
Advise when puting it on:
Put the Belt around everything else accept for the Alternator. After it is around all the rest of the Pulleys - Pull the belt up - tight from the Power steering Pump and the Idle Pulley to form a loop, holding the Belt close to the Altenator Pulley.
Using the 15mm wrench or belt tensioner bar - rotate the Tensioner Pulley towards the front of the Van and then place the belt over the Alternator.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.com!
Posted on Jan 22, 2010
Belt diagram for toro 74805
Go to Partstree,com type in the Model number, then look in the diagrams. If you are looking at the PTO/Hydro Drive assembly then go here:
http://www.partstree.com/parts/?lc=toro_commercial&mn=74805%2C+Z355+Z+Master%2C+w%2F48%22+Mower+and+Bag%2C+2001+%28SN+210000001-210999999%29&dn=3326-242-_2420014-00012
May 02, 2014 | Toro Garden
Belt diagram
HOPE THIS HELPS.. http://www.toro.com/en-us/parts/Pages/PartsDetails.aspx?mybeid=34870&serialNumber=310000001&modelNumber=74366&searchTerm=9lzIRv+p5zeMaPWIo2YCaldb2KV6U4WnyxmRpPSpeQehTowzmaCEK/baRX71tPfJ&defaultTab=parts
Apr 23, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
