Samsung un55d6000 led tv dark spots right lower corner
The samsung is definitely a good tv however... something is wrong... i noticed a dark spot corner on the lower bottom right hand side of the tv... im not sure what is wrong and what i can do to fix it...
4 Suggested Answers
  • 12 Answers
SOURCE: Light green and pink spots on my hd tv!!!
(Yes, this is a cross-post from another thread...I just wanted to help everyone on the various threads on this issue...please do not flame me)
Ok...once and for all I will explain the fix (in detail...which has been missing)...
1) Firmware updates do not fix this problem. I had this problem, and updated my firmware to the latest versons without success. Also, cleaning the light engine (or any other part) does not fix this problem. If you cleaned your TV and your problem disappeared, you had a different problem.)
2) This repair requies a special tool from Panasonic. The tool is part number LSUQ0100. It is light grey in color, and is roughly 7" x 5" x 1" in size. It has diagnostic lights on it, and a button to press to start the procedure. This tool is used to reprogram your EEPROM. Again, this is VERY different than flash upgrading your firmware.
3) To repair the TV, the repairman must remove the lower back of the unit and plug the long, 5-wire connector (5 individual wires terminated to one female connector end - reminds you a bit of an old-style CD-ROM audio cable used in computers) into a male recepticle on the light engine.
4) The procedure takes roughly 6-7 minutes to complete. The TV remains on during the procedure (yeah, I was a bit surprised too). About mid-way through the procedure, your colored ball-shaped blotches will just disappear....no on-screen progress bar, no bright flash, the spots just disappear in the blink of the eye.
5) CALL PANASONIC!!! They are standing behind these TVs, and are covering these in-home repairs free-of-charge - EVEN IF YOUR TV IS OUT OF WARRANTY. Mine was out of warranty by over a year. The Panasonic rep was very kind, but did explain that this is the only repair for these TVs that they will cover out of warranty, as it was a defect in the manufacture of the unit - all other repairs are at the expense of the customer.
Good luck to all - I hope this helps some of you!
Cheers to Panasonic for standing behind their products like this....you don't see that very much these days!
Thanks,
Chris
Posted on Sep 25, 2008
  • 4 Answers
SOURCE: screen appears blue
It's the Light Engine (also called an Optical block) -very expensive.
Posted on Jan 08, 2009
  • 35 Answers
SOURCE: dark spot on the right hand side of the screen
check make sure you didnt put your tv next to some thing that has a magnet in it such as speakers either from a radio or home surround sound system this will cause the problem and if its been sitting beside a magnet for awhile your probably not going to be able to fix it
Posted on Feb 25, 2010
I have a Sharpe LC-60LE600U. The power went out on it. What power board works on that TV. The lower left hand corner has a black spot, too. Will the power board fix the black spot as well?
Power Board wil not fix black spot. the spot is caused from lamp failure. Led strip has at least one LED out, takes out the whole section. Go into trouble shooting to verify. After so many start ups with the black spot, the TV will not turn on in TV mode.
Sep 22, 2016 | Sharp Aquos Televison & Video
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
I have several large water spots on the lower right corner of the tv from overspray with windex. Can this be fixed?
Not a good idea to clean tv with windex. Try wet towel dipped in mild soap solution. Make sure all water has been removed and towel is only wet. When tv off, try removing the spots. Turn tv on only after tv dry.
Dec 22, 2013 | Apex Digital LD4088 LCD TV
Dark spot on led tv
Possibly faulty LED diode. I recommend taking your TV to your local repair shop. You can try to dissasemble your TV yourself but its safer to hand it to profesional.
Apr 10, 2013 | Westinghouse 46? 1080p Led Tv ld4680 /...
I've noticed a dark patch in the lower right corner of the screen. Is this a bad panel or backlight? It's mostly visible in scenes containing blues.
Sounds like a backlight is out probably due to a bad inverter board. If you can see the spot when the tv is off its probably a bad lcd panel.
Mar 13, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Dark screen on TV
This sounds like a speaker got too close to the TV.
Degauss is built into many tv's check for it in the menu.
Otherwise, yes a TV shop or yourself will need to degauss the TV.
May 14, 2008 | Televison & Video
DARK SPOTS!!!!!!!!!!!
Well depends on wether you what liquid you cleaned it with, because you are supposed to use the actual screen cleaner, if you use windex it takes off the finish on the TV and that may be what caused the dark spots. If not so I really do not recommed doing it yourself, it may just cause more problems, depending on when you bought the TV I recommed getting a TV repair man out there.
Apr 14, 2008 | Insignia IS-LCDTV32 32 in. Television
Samsung LCD Question
The model is a LN-S4041D. A 40 inch LCD. I can send you a photo but I can't get the file size small enough to post
Feb 09, 2008 | Televison & Video
Dark spot in bottom right corner of screen
Is this a DLP or a conventional 3 tube projection tv?
Sep 15, 2007 | Hitachi 50V710 50" Rear Projection...
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
Electro Med Services...
