Question about John Deere Garden
REMOVE SEAT SWITCH ON A JOHN DEERE LA125 - John Deere Garden
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 133 Answers
SOURCE: John Deere Sabre 14.5/38 HYDR lawn tractorWont't
See if there is a plastic connector on the wires leading to the seat switch. If there is try disconnecting it and use a piece of wire (with insulation on it) to use a jumper. There is probably two wires coming from the tractor to the seat. After disconnecting Place one end of wire into the wire connector coming tractor and the other end of wire in the same connector on the other side. That will act like the seat switch is closed like you are setting on it. Try and start. Had the same problem on an electric hyster at work and that was the fix we used because the switch is pretty expensive and a hassle to change.
Hope this helps
roundo4
Posted on Aug 04, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
John Deere la125 somebody rigged PTO so it's engage always and causing mower not to start or starts hard.what am I looking for to correct this?
find the wires to the PTO and trace then back to the switch
connect correctly(Probably done because of a faulty switch in the first place )
May 26, 2016 | John Deere Garden
Wiring diagram for john Deere model # 125
John Deere Riding Mowers
Richard, Check the attached links,instruction and guides for wiring diagram. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wiring diagram for john Deere model 125 Google Search
John Deere Lawn Mower Battery Keeps Dying
HOW TO TEST REPLACE SOLENOID ON LA125 JOHN DEERE MOWER
john Deere model 125 Schematic Google Search
Apr 08, 2016 | John Deere Garden
Have a John Deere La125 with only 13 hrs on it. Starts, but won't go in to fast throttle without wanting to die. It seems to be running a little rough in just idle mode. What could the problem be?
Hi Marsha:
If you've been running in a dusty situation it may be that the air filter is clogged. There should be a cover that you can remove to get at the filter. Remove it and give it a good clean.
I may be frowned on for this suggestion, but if you have blown or vacuumed it so it's nice and clean, start it up without the filter, just for a minute, and see how it runs.
Re-install the filter before you go back to work.
May 28, 2015 | John Deere Garden
La125 john deere
Check the blades for true. If one is bent from hitting something that will cause uneven cuts.
Sep 08, 2014 | Garden
John Deere 790 stalling out
My problem with my John Deere 790 stalling was my safety seat switch. It's a quick fix! What I had to do to fix my 2006 John Deere 790, was:
1. Un-hook the switch wires under the seat that connect to the seat switch.
2. Then, connect all of them with little wire clamps (or you can use a raw wire and connect them all) inside the wire connector, with the 4 connectors in it, to bypass the seat switch. Hot wire all of them together. It somehow resets the switch.
3. Then, with my 790 Deere in neutral, I started it up and held the key in starter position for about 2 seconds. (Instead of letting go right when it fires up) Somehow, in doing this, the seat switch reset and I was able to reconnect the switch and the seat switch works as it should now. My Deere 790 front loader fires right up without stalling now, while in neutral, of course. So, try this first because it's a quick fix. I hope this helps.
Cheers,
Aaron
Nov 15, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Every time I lift off the seat of my John Deere engine Dies....
The seat switch is doing it's job,you can;t get off the seat unless the pta is off and the tractor has the park brake engaged.Replacing the switch won't change anything.
May 16, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How does it start
You need to disengage the pto or the seat switch is not working.Try bouncing on the seat a few times and take a look at the pto switch wires,let me know what you find out.
Apr 23, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
89 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
