Question about Refrigerators
Pelonis evaporative cooling fan model : ACS120-A3R
How to use the ice box ? do I have to remove the blind cloth frame or not ?
  • 143 Answers
SOURCE: Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
MNTECH
  • 1543 Answers
SOURCE: not cooling
Sometimes when the evaporator fan goes out, it takes part of the motherboard also. (part number WR55X10552, which also subs into a WR55X10656) If this is the case, I would not expect the refrig to be running either. (If your compressor still runs, check door switch.)
Posted on Dec 09, 2008
SOURCE: bought open box product didnt come with owners manual. Just wondering what the evaporate option does on it. Does it make it blow colder air or no
The evaporator button turns on what is similar to a conveyor belt on the back of the unit. The two rollers, one at the bottom of the tank and the other is above the blower, is just like a conveyor belt, but instead of a black belt it's a white absorbent cloth. When turned on the rollers start moving the white cloth in a rotation into the tank at the bottom that is filled with water and two ice packs (you get 4 w/ it) and I put in a tray of ice cubes at night. . As it goes down into the tank it absorbs cold water and as it goes up the blower is drawing in cold liquid molecules from the white cloth, then the cold liquid molecules are drawn through the blower and out the front of the unit. This conveyor system does remove so you can remove the tank to add or change the water. This is also a filter on the back. When the Evaporator is off the conveyor just is not on. I hope I made any sense, lol. I am not a technical writer and spent 15 mins trying to explain it. I hope I helped.
I just purchased one at WalMart. I realllly like it. I have a room w/ no windows. One little air conditioner at the end of the apartment so I get none of the cold air. I heard about this so I got it. I love it! At night I don't have to have all these fans that stiffen my neck and makes it sound like I am in a airplanes turbine. Just this baby with two frozen packs at a time. I put a tray of ice cubes also at night. You do not feel water on you but it's definetly much cooler then a fan. Especially in humid conditions. People who say it sucks or does not work. They probably expected to get a stand alone air conditioner for $80 instead of $300.
The customer service # that came w/ mine is 866-876-4332 9-5 cst M-F or MideaUSA@aol.com
Posted on Jun 22, 2009
BIKER T
  • 909 Answers
SOURCE: Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
Posted on May 23, 2010
heatman101
  • 43501 Answers
SOURCE: Samsung model RS2530BBP is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 10, 2010
My fridge is not cool enough everything else fine
either the evaporator coil is iced up from a non operating defrost heater or the damper vent door isnt opening to let cool air in from freezer box,also make sure evaporator fan is running to push cold air into fridge from freezer
Jun 30, 2011 | Refrigerators
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Bought open box product didnt come with owners manual. Just wondering what the evaporate option does on it. Does it make it blow colder air or no
Apr 27, 2009 | Heating & Cooling
Cooling sometimes, freezer leaking water when it stops freezing
It is probably the defrost thermostat located on upper condenser coil to the left of the fan in the freezer compartment. If not, it could be the defrost timer located near the thermostat in the refrigerator under the plastic dome where the light is. If the defost thermostat or defrost timer is not cycling the defroster heater element on and off correctly... an ice dam forms clogging the drain tube which freezes and blocks water (from the the defroster) to draining down and into the evaporator pan located on top of the compressor in the rear of the unit near the floor.
Mar 31, 2009 | KitchenAid Refrigerators
My U-line under counter refigerator ice maker evap fan failed
Depends, for the newer models, you can change the evap fan motor thru the front, but if you have the older model, then you have to remove the freezer housing, ice maker assy then the cover to change the evap fan motor.
Nov 13, 2008 | U-Line COMBO29FF Origin Series...
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Magic Chef RB19KA-4A not cooling. Compressor is running as I can observe frost on the copper tubing. Condensor coils were cleaned off of dust but overnight the freezer temp only got down to 45 deg F. Any...
It was determined to be a malfunctioning defrost timer. The freezer box bottom was removed (not an easy thing to do) and the coils found to be a solid block of ice. The timer would not start the defrost heater, hence the freeze up. The timer was replaced and the chill box is back in action.
Jul 22, 2008 | Magic Chef Refrigerators
Ariston Fridge not cooling - Frozen Coils
Try to check the noisy fan, slow rotation of fan can cause the icing evaporator. Unplug the unit and rotate the fan manually by your finger check if the fan is not misalign or not touching the fan frame. Or check if fan motor bearing is not worn out. Under charge of gas is also one of icing cause.
Feb 20, 2008 | Ariston Technologies CBC96 Wine Cooler...
Refrigerators Logo
299 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
