Question about Garmin StreetPilot c340 GPS Receiver
Where to only provides the state you are in--can't be changed
When where to is selected and address is depressed the device only goes to the state you are in. How do I fix this so that it will ask what state and allow me to go there?
    Problem Solver:
  • 5 Answers
It sounds as if you have an older software. However newer software, don't press address, but rather press near... at the bottom of the where to page, and select"a different city" or on the where to page select spell, and spell a name that you know appears in the adjacent state, but not yours...
Good Luck, GB_C
If this doesn't work, upgrade your software, and try anew...
Posted on Jan 12, 2008
SOURCE:
Trying to type in an address on my 1st gps.
The manual can be downloaded from Garmin.
www.garmin.com/manuals/3130_OwnersManual.pdf
1. Touch Where To? > Address.
2. Change the state, the country, or the province, if necessary.
3. Touch Search All. If you know the city, touch Spell City, enter the city/postal code, and touch Done. Select the city/postal code in the list. (Not all map data provides postal code searching.)
4. Enter the number of the address, and touch Done.
5. Enter the street name, and touch Done.
6. Select the correct street in the list, if necessary.
7. Touch the address, if necessary.
Dec 14, 2011 | Garmin Nuvi 1350LMT
I have a garmin nuvi 680 when I push where to, then address it goes to my home state of Pennsylvania how do I change the state to virginia I see no when on screen to do this
Press Where to, and Address, In the bottom right hand corner you will see Change State/Country press it then select Spell State/Province - Type Virginia.
If not working, It could also be Penn saved in your favorite places, on Menu, select where to, favorite, and edit it from there. If you want Virginia to be your home state, but you already have Penn saved as your home state, you will have to delete Penn first before you make Virginia is your home state. You will do it from where to, favorite, home, edit, and delete, and you can set new home state by press Where to, Go home and set for Virginia.
Hope the helps
Thanks
May 25, 2011 | GPS
How to change the city on the view map screen?
Where To..... Address..... on this screen you will see on top Select City in.. ( below the State chosen )
if that is not the State the city is in then change the state on bottom of screen to the one you want by pressing Change State / Province
if you need to change a city just press Spell City to the one you want after your state is selected
Nov 20, 2010 | Garmin nuvi 1490T GPS Receiver
Keeps saying no address found
well you didnt say much to figure this one out but lets give this a try....
don't know if the address is new or old you are trying....
go to Where To.... Address........on this page where it says Select City in _________ below is that the
State selected you want to look in for the address ?? If not you must change the State you are looking in onthe bottom of page press.....Change State / Province to the State you want to look in
Nov 12, 2010 | Garmin GPS
When I press address it goes straight to Street. It doesn't ask what State. If I put in address....it says not found. Brenda Romero
need a lot more info .... what gps model do you have,
your saying you put address it goes straight to street? then say i put addrees it says not found
Most Nuvi units you have to press Where To...Address....and on the bottom of screen you will see Change State / Province
First select your State..... then go back and select the City... it should now let you put the number of house press done ..then the street name
Nov 06, 2010 | Garmin GPS
When I try to spell states it goes right to no matches found on the 1st entry
After powering up the unit and selecting address, the unit displays, "In What State is the Address? and Spell State. When I press Spell State, it has No Matches Found. When I press Back and attempt to enter the first letter of any state, the unit displays "No Matches Found".
Sep 17, 2010 | Garmin Nuvi 350 Car GPS Receiver
If your home state is programmed in for Mississippi on the GPS and you want an address in another state, how do you change it? It automatically goes back to Mississippi.......??
go to the where to tab, then address, then select state. you should have to options there. one is your state, the other is other states.
bill
Oct 20, 2009 | Garmin nuvi 255W GPS Receiver
When I go to spell a state, the screen goes immediately to the Select State Screen. It will not allow me to spell the state.
When you type a stae it will automatically show the list of states you can scroll down to check if the states is in the list or if the states is not recognize try to check the region make sure your in lower 48 states.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin 360 keypad stuck
operator error - search doens't work with Topo maps, only city navigator. changed map and worked.
Aug 20, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi --Can't put state in for address
Turn on the unit and go to Settings
Then select Map
Then select Map Info
Verify that there is a check mark next to City Navigator North America NT
May 17, 2008 | Garmin nuvi 350 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
126 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
