Question about Refrigerators
Godrej pentacool good evening sir MY godrej is giving cooling on upper section call deep freezer and below where we keep all major stuff we can not get cooling please guide us
applianceboy
  • 77 Answers
SOURCE: Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Posted on Sep 26, 2007
  • 46 Answers
SOURCE: 2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
Posted on Aug 01, 2009
SOURCE: Godrej Pentacool Model No GF21 is not cooling
godrej pentacool get more moisture plaese solve this problem
Posted on Aug 18, 2010
  • 266 Answers
SOURCE: there is compressor sound problem
Im taking that you have a fridge that works fine you just have a noise that is bothersome. The easiest way to correct vibration noises is by pushing on the compressor or surrounding coils until you find the offening spot of vibration. You can buy damper pads but you can use a piece of cardboard wrapped in duct tape. Fold it so it is thick enough to wedge into the area that is vibrating to get rid of the noise. good luck
Testimonial: "plaese send your solution in easy words thats ok for me"
  • 64 Answers
SOURCE: I HAVE A GODREJ PENTACOOL
Most times the coils are getting dirty and just need to be cleaned off. They are normally now days under the unit. You can get to them by removing a panel in the rear or by removing the front lower grill. Once you gain access just clean the lint/dust off. Compressed air will work best. Check out this video to assist. It seems to be of help.
http://www.youtube.com/watch?v=gXhDHk7xzww
Posted on Apr 24, 2011
I have a godrej refrigerator, pentaciol model. in
My name is Peter, retired Sears Home Services Tech. You must know something to mention the Bi-metal. When you pull off the back wall freezer cover do you have a nice frost patter on your evaporator coil? Is there allot of ice in the upper right hand corner? If so you have a restriction. This means the evaporator coil & the line filter has to be replaced. This is a major repair by an experienced tech.
This is about a $450-$600.00 repair.
Oct 11, 2014 | Refrigerators
I HAVE A GODREJ PENTACOOL REFRIGERATOR. It is not cooling as much as it used to. The compressor is working, it is also warmer at both the sides, as it used to be. I would like to know at what point I am to...
Apr 24, 2011 | Refrigerators
NEFF K4663 fridge. the freezer works ok but refrigerator space does not go below 9deg C even at highest setting. have defrosted and water drain is clear.
The defrost board is not functioning properly.;
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Neff Refrigerators
There is compressor sound problem in godrej pentacool refrigeratore
Aug 18, 2010 | Refrigerators
Stop cooling every 5 days I defrost manual GSS201ETCBB
Does the freezer / fridge door close good? Check the hinges. Also check the seal and the amount of food stuff you may have close to the door. If you have an ice maker make sure you have it secured inside the freezer section.
It sounds like something is keeping the freezer door open or from closing good.
Mar 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Godrej Pentacool Model No GF21 is not cooling properly, please solve this proublem.
Feb 13, 2010 | Refrigerators
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Warm Fridge Section
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
