Question about Refrigerators
Samsung parameters
Hi i m a fridgeman usually working on supermarket & came across that samsung fridge to help my bro in law. would like to have the parameters access & list of that samsung RSH1DTMH as i change the df probe but want to verify through the board what s the reading & settings. samsung seem to be really reluctant to leave any info on the net. any clue ?
SOURCE: American fridge freezer - sansumg rsh1dtmh
I had the same problem. There is a circuit board on the very top of the fridge/freezer. There is a 5amp quick blow fuse on there. Sounds like that has blown. Mine did for performing the same function. replaced it and all is good.
Posted on Feb 20, 2008
  • 256 Answers
SOURCE: Samsung RSH1DTMH fridge/freezer - Left hand side
Usually, there is an issue with one of the following:
* electronic temperature control located in fresh food compartment
* defrost thermostat and/or heater(s) located in freezer compartment
Contact an appliance service company.
Posted on Feb 16, 2010
  • 3 Answers
SOURCE: error codes for Samsung Fridge
does anyone know what error code 3 is? Have the same problem, wont cool on fridge side freezer side is fine...
Posted on Mar 01, 2010
  • 3 Answers
SOURCE: My Samsung RSH1DTMH Fridge Freezer the fan started
We had the same problem with our Samsung RSH1 fridge freezer. We bought a kit from a company called Appliance DIY Repairs, that were recommended to us by a friend. We fitted the kit. It was an absolute doddle - and considerably cheaper than getting an enginer out to fix it.
Posted on Aug 07, 2010
  • 117 Answers
SOURCE: Samsung RSH1DTMH fridge freezer. All of a sudden
HI THIS SHORT VIDEO MAY HELP">
Posted on Sep 16, 2010
My samsung freezer door does not close all the way causing frost buildup. I have replaced the gasket and leveled the fridge.
The hinges usually have some adjustment on them. Two person job, or put something under the bottom of the door to support it. Loosen the hinges a bit, pull the door forward at the hinge which should close the gap on the other side. Tighten down the hinges and check again.
Jun 16, 2016 | Samsung Refrigerators
I have a Sainsbury microwave SKU 126251366 and no user manual. Can anyone help?
SKU number is not a lot of good as this is the just the sales code on the supermarket shelf. You would need a make and model number. Sainsbury's didn't make it, a microwave company did. By law, there should be a model number on the back with voltage, amps, and serial number.
Google
<model number> manual
or
Try Sainsbury's direct.
http://www.sainsburys.co.uk/sol/iw_container_page.jsp?pageRef=sites/www/Events/Large_Appliances.page
Aug 08, 2015 | Microwave Ovens
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
Samsung LNS4041DX/XAA White horizontal lines
Hi my name is Roety,
I can help you with your issue ,
If the lines are present on every input you most likely have a bad screen. We usually replace the mainboard first because its cheaper .
Check part prices at encompass.com login as a guest
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
My husband tried to fix the dryer and it stoped working so my bro-in-law is here to fix it. When my huusband took some of the wiring apart he put it back wrong and my bro-in-law needs schematics to put it...
Just look close at the wires. there are numbers on them. The matching numbers are on the timer. The heater and limits have different sized terminals.
Jan 03, 2009 | Dryers
Fridge not working
Hi steven, Maybe this could help? Has anyone moved the settings on the fridge? Your fridge is actuallty controled by the freezer with a fan and flap in the fridge compartment. These sometimes ice up and do not let the cold air into the fridge if this is the case then i would switch it of and defrost it ( Yes it is supposed to frost free ) But they do fail. Check to see if it has two compressors on it? see if the fridge one is work and hot as it could be independant from the freezer depending on the spec!
Hope this helps?
Dec 28, 2008 | Refrigerators
My samsung side by side giving me problems
Your problem with you fridge freezer.. Samsung have cocked up on the design of the back plate of the fridge.. There is a modification back plate now. This has a metal plate fixed on the back. when it is fitted the plate rests on the heater for defrost. the heat transfers through the plate and stops the back frosting up.. the frost causes the fan to stop.. Hence the modified back plate. i have come across many problems with these machines. hope that helps.... Kind Regards mcdapp..
Jul 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Samsung side by side fridge/freezer
BURY IT, NO ONLY JOKING, YOU DO HAVE A DEFROST FAULT, SAMSUNG ARE RENOWNED FOR THESE FAULTS, REMOVE THE BACK AND CHECK THE FOLLOWING, YOU WILL HAVE A DEFROST SENSOR, USUALLY TWO YELLOW WIRES WITH A WHITE BULD ON THE END, PUT A MULTIMETER ACROSS THE END OF THE WIRESES AND HOLD THE WHITE END IN YOUR HAND TIGHT, YOU SHOULD SEE THE RESTANCE CHANGING, IF NOT IT IS FAULTY, TO THE RIGHT OF THE EVAPORATOR YOU WILL SEE BLACK AND RED WIRES CHECK YOU HAVE A CIRCUIT THROUGH THIS ITEM, IT IS A THRMAL FUSE, IF THAT IS OK THEN METER OUT THE TWO HEATERS, IF THEY ARE OK THEN YOU HAVE A POWER MODUE FAULT. REGARDS ADVISOR
Aug 24, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
