Question about Boating
Alternator where is it located on a 115hp 4stroke outboard
    Top Expert:
  • 43,095 Answers
Under the flywheel .remove the big nut on top , this will not be easy,holding flywheel is critical if yyou turn it backward you might ruin the water pump impellor . you need a flywheel puller to get it off .then the nut needs to be retorqued when putting back on.
Posted on Jul 07, 2014
  • 77 Answers
SOURCE: T50 4stroke yamaha outboard
that engine should be electronic ignition, so I would suspect your problem is your coils.
Posted on Jul 12, 2009
  • 302 Answers
SOURCE: How do I winterize my Mercury 115hp outboard motor
add Stabil to the gas tank and run the engine for a few minutes so it gets into the carb. Then pull the plugs and spray fogging oil into each cylinder and then turn the engine over a few times. If you are in a cold climate you should drain the lower unit in case there is water in it and then refill it with new lower unit grease. reinstall the plugs and you will be ready for winter.
Posted on Nov 01, 2009
  • 43095 Answers
SOURCE: where is the serial number on mercury 115hp 6 cylinder boat motor
http://www.marineengine.com/mfr/mercury_models.html
Posted on May 01, 2010
SOURCE: How and where do I remove the gear linkage so I can remove the leg from a Johnson 115hp outboard motor Model J115PXSRC serial number 05037458
Please contact me at +270782863573 Thank you,
Ben van Schalkwyk
Posted on Jan 10, 2012
  • 5 Answers
SOURCE: how to remove lower unit on 1990 115hp Johnson outboard
First thing you need to do is remove the shift pin it is located underneath the carburetors it is a 3/8 head you will probably need a 1/4 drive swivel socket. After that you can take the bolts that hold the lower unit on off. I think there is four 9/16 bolts on the sides and a 5/8 above the prop and you might need to take the trim tab off and get another bolt under there. It might take a dead blow hammer to get it loose. If you are doing a water pump it is pretty easy just make sure to spin the drive shaft clockwise while putting the housing back on
Posted on Dec 03, 2012
Is a 1978 Johnson 115hp outboard a two or four stroke
for that year of manufacture 4 strokes were not the normal thing in outboards
if it doesn't have rocker covers and rocker gear it is a 2 stroke
Jun 24, 2017 | Johnson Boating
Mercury outboard 115hp 1995 water pump replacement
If you have never worked on an outboard please take it to a professional mechanic.
If you have really good mechanical aptitude you can do this... first purchase a factory/clymers/Seloc service manual.. you WILL be glad you did!! Explaining all the details on here would take a while!!
MarineEngine.com
May 27, 2017 | Mercury Boating
How do i wire an internal wire harness on a 115hp mercury outboard
Google outboard engine wiring color codes
Sep 11, 2014 | Boating
2005 115hp 4stroke merc tach not working
this is cars and trucks,
try boats.
May 30, 2014 | Cars & Trucks
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
