Question about Exercise & Fitness
Techno/oma treadmill error 6 - Exercise & Fitness
What is OMADM has stopped? and is that something bad?
Hey Julia,
OMA Device Management is a device management protocol specified by the Open Mobile Alliance (OMA) Device Management (DM) Working Group and the Data Synchronization (DS) Working Group. The current approved specification of OMA DM is version 1.2.1, the latest modifications to this version.
Carriers remote control software continues to put some mobile devices at...
OMA DM protocol support
Jun 23, 2017 | Miscellaneous
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Error code AC-6
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
[PDF]Precor Error Codes
My techno gym treadmill 700 indicates equipment is blocked code (4) how do I fix this problem. Thanks
Can be one of many problems.
Can be as simple as a limit switch not resetting.
Can be a cable is bad
More often than not it's the lower kit (electronics near the motor) that is blown though.
Mar 09, 2015 | True Technogym Excite Run 700 Treadmill
As soon as my treadmill is powered on I get an error code of dC-6, and it won't function, how can I fix this?
Hallo,
Fisrt of all, i hode like to thank you for you kindness.
I have more details of the machine.
Marc: GREEN MASTER
Model: 928
i Hope that can help you.
Thanks again
Sincerely
Carlos Silva
Feb 14, 2014 | Lifespan Fitness Treadmill Walking Belt...
We have two commercial treadmills of your company with following details: 1- Technogym Run Exc 700 (Serial # D447ELNAL0000UKS) 2- Technogym Run Exc 900 (Serial # D4492LNAL0000USS) Now problem...
Might be the top panel monitor is faulty Also check that the treadmills are set into km not miles can effect the volt of treadmill and cause errors on treadmill Tip go on to techno gym site and look for display reset something like that and give that a try
Oct 08, 2013 | Exercise & Fitness
Techno woshing macine e2 error code
please adjust the speed sensor, see the diagram , clean it , test for open or faulty, tight the connector very well. Run the software calibration for easy diagnost and fix it.
God bless youca6ac285-0d3b-4f8d-be08-b95be3c0bc40.gif075f693e-e499-4a20-a99a-23cd2bdd1cbd.gif
Jun 06, 2013 | Exercise & Fitness
Oma-002mb what the weght can this tread mill work my weght is 125kg can i trainning in this tread mill
yes you can every treadmills made for hourse training can weight for 250 lbs aprox.
Happy new Year.God bless you
Dec 31, 2012 | Star trac ST Fitness 8921 Treadmill
Lifetrack OMA-117 treadmill constant beeping not moving
1) adjust the REED swithc , see the diagram clean , and tight the wires connector very well.
2)Try to RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jun 29, 2012 | Exercise & Fitness
The equipment is blocked
hi all i have run excite ur 500 treadmill from techno gym company i face block on screen i think it's board problems if anyone can have any idea contact me at email: alex.freemas@gmail.com
May 08, 2012 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
