Question about Magic Chef Refrigerator. 10.0 cu. ft. Refrigerator in White MCBR1020W
Magic Chef Mod # MCBR1020W - light is on but moter is not running, no cold.
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
docjohn174
  • 943 Answers
SOURCE: Does not get cold enough.
HI THANKS FOR YOUR QUESTION.tHE FIRST THING TO LOOK AT IS . iF YOU HAVE FROST BUILD UP ON THE WALL, OF FREEZER.#2. IS THE FAN RUNNING. #3. CLEAN ALL COILS AT THE BACK, OF FRIDGE, VERY IMPORTANT . tHANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
kel1guy2002
  • 3740 Answers
SOURCE: Refrigerator not making ice or getting cold
Hi and welcome to FixYa. I am Kelly
Your symtom comment that it is barely getting cold leads me to think the problem is in the automatic defrosting of the refrigerator.
Your unit has a mechanical defrost timer. It is item 6 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168518&diagram_id=1349648#d1349648
If you look at the panel all you will see of the defrost timer is 2 raised / tapered tabs that would only allow you to rotate those tabs in one direction.
Use a flat bladed screwdriver with a good blade or a rather wide flat ended kitchen utensil to rotate the defrost time until the compressor shuts off. That is the beginning of the defrost cycle. Leave the unit sit for about 1 hour and see if it performed the defrost cycle and restarted the compressor.
If the compressor did not restart.... there are other components of the defrost circuit that have failed.
Those components can be any one of the following:
1. The defrost timer itself.
2. The 60 deg bi-metal thermostat
3. The defrost heating element
4. A wiring problem to any of the above
If the unit did not defrost at all.... what you can do is perform a manual defrost by unplugging the unit, emptying the contents of the freezeer section and placing a fan blowing into the freezer section for just over 2 hours. This WILL make a WATER MESS so be ready to tend to the drips with rags and a mop.
After that 2 hour manual defrost reload the freezer and plug the unit back in. The temps should return to normal in about 4 hours.
If the manual defrosting corrects your no ice and warm fresh food problem then you for sure have an automatic defrosting problem.
One thing to note is.... if the evaporator fan in the freezer compartment is not running you will have a warm fresh food compartment and no ice. If the fan is NOT running and the compressor IS running the evaporator fan has failed.
The wiring diagram for your Refrigerator can be found here:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1326763&pkw_=basket&model_id=5168518&NewWindow=1
Thanks for using FixYa,
Kelly
Posted on May 01, 2010
mycem
  • 9 Answers
SOURCE: Magic Chef refigerator/freezer stopped running
if you said stop running id assume that there is no power?? even with good electrical input..
for that instance, better check.charred cables.. if not there maybe a problem with timer itself..
Posted on Sep 09, 2010
  • 132 Answers
SOURCE: I have a Magic Chef
Is this a two door refrigerator?
If it is then their is an air duct that allows some air from the freezer to cool the fridge section.
Three things to look for;
Is the air duct blocked
Is the fan blowing air
is the freezer coil frozen over.
Try manually defrosting the fridge. If that helps then you have an auto defrost problem. A technician can help you there
Posted on Apr 01, 2011
MCBR1020W is the model number for the refrigerator in my apartment. The refrigerator fresh food unit is not getting cold enough to keep food cold, this results in food spoiling. What could be causing this...
You could have the lack of air flow or a door seal problem. Could you check the freezer for me, look for frost on the back wall. If not frost, is the fan running in the freezer?
Please get back to me
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 08, 2011 | Magic Chef Refrigerators
I have a Magic Chef Refrigerator Freezer Model MCBR1020W. It is a small 10 cubic capacity for my basement. It is about 18 months old. The freezer works great but the refrigerator compartment never gets to...
Mar 31, 2011 | Magic Chef Refrigerators
My MCBR1020W 10 cu ft top mount freezer/refrigerator is not cooling correctly. It is -20 degrees in the top and 60 degrees in the bottom. This is a new item.
It is a cheap piece of junk. I bought one just this week and the defrost timer gets stuck so it's going back...........
May 14, 2010 | Magic Chef Refrigerators
MCBR1020W, 10cf., new fall 2009, defrost stops working
Good day,
You have an unlimited warranty for the first 12 months, and are entitled to a proper repair.
Could be a factory defect.
My advice is get hard nosed with them. The people you are dealing with did not design the machine but are responsible to correct or research or worst case scenario replace the machine.
The factory will eventually compensate them.
Apr 24, 2010 | Magic Chef Refrigerators
Refrigerator bought in Oct. 09 has now quit cooling at all, on 4 occasions. Is anyone else having this problem w/this model #MCBR1020W
Just bought one at Home Depot. The Freezer is frozen and the refrigerator half is luke cold...if theres such a term. Anyway I bought it for a tempo while my GE gets repaired...ant win for losing on this issue...lol
Feb 11, 2010 | Magic Chef Refrigerators
Magic chef gas/electric rv fridge freezer gets cold but fridge dosn't
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Jul 15, 2008 | Magic Chef Refrigerators
Magic Chef Refrigerator. 10.0 cu. ft. Refrigerator in White MCBR1020W Logo
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
