Thank you so very much, my machine is now working properly. Love that simple but complext solution.Thank you so very much, my machine is now working properly. Love that simple but complext solution.
You can't post conmments that contain an email address.
The model of the copier is usually pretty important but try this and you should be up and running soon
type in 1087 1087
wait for the screen to show 000
type in 163 and hit the start button
you may seethe word execute on the screen (if so then select it and confirm with either the green button or the silver one) this resets your fuser unit
if this does not work you will have replace parts in the fuser or replace the whole fuser unit
Hi
I found this explanation of your error, although my understanding of it is not entirely clear. Code: C6400 Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s. Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here: Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Good day, if your error is toner then make sure the small white gears on the back of the toner cartridge is turning, if they are not then replace toner bottle, if they are turning ask a technician to test the toner motor. If your machine displays error C6400 then enter service mode by pressing 10871087, now press 163 and OK, now restart your machine, if the code is still there then you should replace your fuser/fixing unit.
Hello, the c6000 is the Fuser heater 1/2 defective --- but is you are getting the c6400 --- is a zero cross signal error which means defective PWB. You must replace the engine PWB or the power source PWB and check for correct operations.
The cheapest route would be to replace the fuser but with the c6400 code I believe you would just be throwing your money away.
copiergeek thanks it did reset the fuse and it's working again thanks again
