Had a Toshiba estudio 4520c and is continious giving Error code CE71, How can I fix it?
  • 1126 Answers
SOURCE: Toshiba estudio 166 C44 error code
Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Do Not keep resetting, may cause damage to Fuser Unit.
Posted on Sep 14, 2009
mce_sys
  • 41 Answers
SOURCE: toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
Posted on Jul 24, 2010
  • 66 Answers
SOURCE: Toshiba estudio 3511 keeps giving error c360.
At our repair shop we have begun to put a small (1/8" or so) washer in between the frame and the bracket the worm gear is attached to when we get this error intermittently. It seems to pull that worm gear closer to the main charge cleaner gear to give it better meshing. Hopefully this helps you!
Posted on Aug 17, 2010
  • 132 Answers
SOURCE: toshiba estudio 351c error code
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Posted on Apr 12, 2011
SOURCE: toshiba estudio 161 error ode h2 when we switching on the machine
H2 PROBLEM CRATED
PLZ GIVE ME SOLUTION
Posted on Aug 08, 2011
How to fix error code C280 for toshiba studio 355
Check home position sensor connector, replace home position sensor, replace SLG board
Apr 25, 2017 | Toshiba Office Equipment & Supplies
To clear the code error c413 of Toshiba estudio 2505
How do i clear the error code C413 at Toshiba estudio 2505 thnx, regard asif ali
Feb 08, 2017 | Toshiba Office Equipment & Supplies
I have estudio Toshiba 452, Touching screen and it will hang up.
Try do not touch the screen, will the machine hang? If no, the probably the control panel/touch screen faulty...
If yes, probably the HDD error, what u can try initialize HDD, if problem persist, replace HDD & update firmware
Dec 30, 2015 | Toshiba eSTUDIO 4520C PRO
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
Error f090
H
I have managed to find a description of this error here:
Error Codes Toshiba Studio 4511 Code F090
which says:
Description:- SRAM abnormality on the SYS board
Unfortunately the page doesn't give a remedy for this error as it normally does, but you can download a pdf format service manual from this site by clicking on the link near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Toshiba Estudio 4511 Color Printer,...
What is the reset code of toshiba estudio 181
i have toshiba e studio 181 it gives an error of paper size its not accepting any paper size expect A3 size plzz help how to set paper size
Sep 12, 2012 | Toshiba e-STUDIO181
I have a toshiba estudio 2500c. I have error code C3B0. How do I fix it without calling a service person?
I have a toshiba estudio 2040c. I have error code C3B0. How do I fix it without calling a service person?
Sep 08, 2011 | Toshiba E-studio 2500c Color...
50 people viewed this question
jasbo
jasbo
