Question about Dometic Rooftop RV Air Conditioner
Tempstar ch5536uka1 tempstardlr - Dometic Rooftop RV Air Conditioner
I need a wring diagram for TEmpstar Model # CH5536UKA1
Found this site for Tempstar Dealer Support and I thought it might prove helpful.
http://tempstardlr.com/pfindex.asp
Jan 22, 2011 | Heating & Cooling
Tempstar Door model keeps overfilling
The sensor is a plastic pipe (vacume) / and a ajustable switch. The rise in water causes the air pressure in the pipe to increase and at the set level this stops the water inlet valve. You could disconnect the pipe and blow into it slowly and should hear the switch click. Most faults are the plastic sensor pipe blocked / obstructed and or the switch terminals (inside switch) burnt. This means that the switch must be replaced and should be set for the correct water inlet.
Jan 21, 2010 | Jackson 25 in. TempStar HH Free-standing...
Parts list for Tempstar PGAD60E1K1? Anyone have?
Tempstar will only sell to licensed dealer/contractors. You will have to purchase through your local HVAC contractor that deals Tempstar. They will be able to cross your model # to the correct parts. However, you must have an EPA license to purchase the compressor.
Oct 06, 2009 | Heating & Cooling
What ton is my tempstar pgf048k080a a/c unit
Look for the BTU rating. 12,000 BTU is a one ton unit.
Sep 05, 2009 | Jackson 25 in. TempStar HH-ST...
Dometic Rooftop RV Air Conditioner Logo
27 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
