Question about Garden
Etesia hydro 100 manual
Etesia mower won't start. when I turn on the key there is a click coming from unit under radiator . then nothing on second turn
  • 3600 Answers
SOURCE: John Deere hydro 185 When I try to start
You have a bad disk in the starter solenoid pull the starter and go to a shop and buy a new solenoid or flip the disk in the solenoid and sand the two contacts so that it will make contact.
Posted on Jun 12, 2009
woobie dog
  • 1273 Answers
SOURCE: WHEN I TURN THE KEY ON MY SNAPPER HYDRO IT CLICKS
If the battery is good and fully charged, it should turn over. If you have a pull rope as well as the starter, make sure the engine will rotate. If not, you can do the same thing by placing your hand on the air vent screen on top and twisting the air screen. If the starter was hung up, usually the solenoid won't click. Have your battery tested, make sure that it is fully charged. Although unlikely, the solenoid could be bad. I'm betting it's the battery charge.
Best regards, --W/D--
Posted on Jul 19, 2009
mowerman1857
  • 389 Answers
SOURCE: craftsman 19.5 42' deck will not start.when i turn
Check both battery terminal bolts for good, clean, tight connection. Also locate the fuse just behind the engine on the right side of the mower and see if it may have blown
Posted on Sep 17, 2009
  • 20 Answers
SOURCE: When I turn the key on to start my Troy-Bilt RZT
Do you hear a clicking sound???NO ?? Do you have the speed ?turning handles in the extrem OUT position? Is the ground cable connected to the engine block?? Is the Red cable connected to the + Positive post on the battery?? Is the BLACK cable connected to the - Negetive post on the battery?? Why did you need to replace the fuse? Is the battery charged??
If none of the above corrects the problem replace the ignition switch
Posted on May 03, 2011
  • 252 Answers
SOURCE: Have a Husky yth180 mower.
hi there dolson894
here is web site for owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/yth180.html
download owners yth180 manual it has a wiring diagram in it - may help
sounds like a starter solenoid problem, check for good grounding of the negative bat cable and grounding of the solenoid to the frame , check for 12 volt at the solenoid tab ( not the heavy contacts)
this wire solenoid tab wire comes from the S marked terminal from the main switch and power from the battery is taken from the HOT post of the starter solenoid up to the B terminal of the main switch, from there when contact made between B + L + S @ SWITCH voltage sent to solenoid for start
basic connections for switch in start mode is B + L + S
run / light B + L and Makes A + Y
run B + L off G+ M +L
check seat switch and brake switch - bypass with jump wire if need
across white to wjite wires on brake switch
see what hapens , the try a jump wire across the seat switch wires green to green and retry
if stil no good - replace solenoid as you mentioned with a jump cable straight on start motor turns over good
check out website
cheers hope it helps pauly46
dont forget the thumbs rating
Posted on Jun 07, 2011
My etesia mowers deck engages then cuts out, I think it is the side dead man switch failing but unsure what to do to fix the problem
As a test only. you can get some 3M scotch locks from your local auto parts store and bypass safety switches till you find the culprit. and then order the proper part to repair it properly
just tell the guys at the parts store you need the blue ones How to Install Scotchloks from LEDS
Jul 13, 2017 | Garden
I have an Etesia Bahia ride on which keeps blowing a fuse. Once the fuse blows then the cutting blades disengage and if I switch the engine off it will not start again.
you have a short in the wiring that is touching a ground somewhere. check to be sure the wires are not cracked stretched or rubbed and are up out of the way and nit touching a pulley. it is hard to find a short. be sure the wires going into the clutch are firm and are tight.
Dec 18, 2016 | Garden
Etesia lawnmower
Check to see if choke is closing and opening properly, if yes, adjust the carburetor as it appears you are not getting enough fuel flow with the amount of air intake.
Jun 07, 2013 | Garden
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Etesia drivebelt
This is posted in the wrong product category, please post again.
May 26, 2012 | Cars & Trucks
My 1863 cub cadet won't start
try and jump start it with your car sounds like the battery is weak
Mar 31, 2012 | Garden
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
