Question about Welding Tools
Weldmate 75 welder manual - Welding Tools
Should a Weldmate T100P have power to the wire before you pull the trigger
No. Pulling the trigger closes a heavy duty relay in the main housing, otherwise your torch would be permanently live.
Oct 20, 2014 | Welding Tools
Does welder need argon gas when using steal wirer
Hi:
If you are using solid mild steel core wire, yes you need a mix of gas Argon/CO2 75/25.
Only cored shielded wire do not required gas (also called innershield or flux cored).
Adjust your flow rate for the mild steel wire at 20 or 25 scfh, depending if you are welding inside or outside a shop.
Feb 05, 2011 | Clarke Power Products Clarke 130EN...
Clarke 130en Welder settings for Welding aluminum with .030 wire on 1/4" sheet aluminum
try 75 25 argon helium gas or straight helium helium makes metal melt hotter
Dec 11, 2010 | Clarke Power Products Clarke 130EN...
Will 12-3 braided wire be ok to run 187 hobart mig at 75 feet long 30 amp breaker
I would run no smaller than 10-3, preferably 6-3. I've seen more than one welder burn out due to insufficient extension cords. 10-3 is pushing it for 75', and if you ever plan to extend the leads, you will be money ahead getting the 6-3.
Dec 15, 2009 | Hobart Welding Tools
How to control welding spatterin MIG?
different gas mixes will give different amounts of spatter, pure co2 doesnt spatter too bad, flux core spatters like crazy, and 75/25 has light spatter also
Mar 03, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Welding Tools Logo
376 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
