Question about Refrigerators
Samsung bottom freezer installation of DA97-07603B
Need to install new ice maker unit DA97-07603B
mikedurland
  • 481 Answers
SOURCE: Maytag Refrigerator Ice Maker
  • first make sure the metal arm to the right of it is lowered, this turns the icemaker on.
  • then you can check the water supply to make sure it is turned on, sometimes when houses are vacant they turn the water off as a precaution. the valve may be behind the refrigerator or under the sink in the kitchen.
  • then...
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 04, 2008
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
  • 8 Answers
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Posted on Nov 05, 2008
SOURCE: Kenmore Bottom Freezer 596.71103101 Ice maker not working right
When the refrigerator was moved, the freezer door may have shifted downward. The switch for the freezer light is on the top of the freezer so it turns off the light when the door closes. The icemaker is also connected to that switch so it won't dump ice when the door is open. The solution is to adjust the door elevation. The easier solution is to attach something to the portion of the door that hits the switch. I used a white coverplate for a wall light switch.
Posted on Jan 15, 2009
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
The ice maker will make the ice but I have to manually press the reset button to have the ice dump into the tray. It will not dump ice on its own. This is for the samsung RF217AB french door bottom...
Make sure the freezer is cold enough. If not this might cause problems of poor dispensing.
If your ice makes unit has a 'heater'build into it, it just might be that the heater in the tray does not work..if so, new ice tray dispenser.
Oct 25, 2013 | Samsung RF217ABWP (20 cu ft) Bottom...
Need to replace Ice Maker in bottom freezer
Good day,
3 screws hold the ice maker in place. On some versions the 2 top screws are replaced with clips, but it is self explanatory.
The cover is a tight fit, but un clips from the bottom first. You re-install by snapping it in place with the palm of your hand.
The wire pulls straight out of the front of the ice maker and then you wiggle the rear off its mounting hole.
HOWEVER,
What you described is classic of a bad water valve. Especially the overflow issue. I would change the valve first, and if it still has issues then replace the ice maker.
Apr 07, 2010 | Amana AFD2535DES French Door Refrigerator
Ice maker installation
do you have a water supply line connected to the refrigerator? if so, it connects to the water solenoid, so you wont need to install that. if you have no water line, not only do you need to install that, but you will also have to check to see if you also need to install the solenoid assembly. if no solenoid is present, you will likely also have to run a plastic water line, ¼", from the solenoid up the back wall into the sleeve near the top of the back wall, which feeds the water into the freezer, into the icemaker.
if you want to send a check, id be glad to post a video
Mar 01, 2010 | Amana ABB1927DE Bottom Freezer...
The ice maker wont drop the ice
You need a new ice maker on this unit. They only last about 2 years or so. Call us and we'll be sure to get the correct part out to you right away. We hope to hear form you real soon.
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Freezer Arm Not in Place
well in order for me to hep i would need the info all number on the back of the frig and i assuming u mean the ice maker arm is broke off or just missing so yes u need to arm for the ice maker to work so if u get the info off of the back of the unit and u can prolly go to amana's web site and buy the peice from them and install it yourself if u are unsure on how to install it might try and go to www.diynetwork.com and search on there site how to replace the ice maker arm good luck
May 12, 2009 | Amana ABB1927DE Bottom Freezer...
Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Jan 02, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Kenmore Bottom Freezer Ice maker installation
in the bottom style freezer the plug will be in the upper left hand corner of back of the freezer ,,, may have a cover plate over it but thats where it is and should be a couple small holes with plugs on the upper left hand side for the mounting screws / larry
Dec 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
333 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
