Question about Philips Magnavox 13MT143S 13" TV
Televison issues Please I need help! My television only tunes and automatically selects channels. Now I have more channels on my cable but my t.v has not adapted to it. It only shows channels 1-55 and then skips to 108. I am missing out on about 30 channels because of this. I would appreciate any kind of help.
  • jenn1973 Feb 21, 2008
    Ok.  My TV used to automatically tune in channels every time we turned the TV on. We lost the remote that had the little button that had autotune on it. At some point someone selected autotune and now it is programmed to just 4 channels. I would like to find a way to autotune the TV to the new channels since we have moved. If i had the remote, I could do it by that but sonce it is lost, what can I do?
  • 3,130 Answers
There is nothing you can do, as this is how this set works. You will need to get a new set if you want the other stations.Good Luck.
Posted on Aug 31, 2007
How do i tune the channels on a toshiba rc3910
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
Jul 10, 2011 | Toshiba Televison & Video
I have accidently gone past the automatic tune function when 1st turning tv on . How do I manual tune?
I think you mean perform the channel scan function. Every tv manufacturer has different wording in the menu, but basically this is what you would do:
Press Menu, then go to Setup or Installation menu (wording depending upon mfg).
Select antenna or cable (wording could be air or cable)
Perform channel scan
Hope this helps as you didn't mention model.
May 17, 2011 | Televison & Video
How to get and store all the channels automatically?
u can auto tune ur tv for storing channels aromatically through the following steps
1. press MENU button and then select CHANNEL and press ENTER.
2. select country and press ENTER AUTO TUNE and press enter.
4. press ENTER again.
wait till it memories all available channels.
after auto tuning it will display sort channels. if u want to sort channel, do it, if not exit the option.
Dec 15, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
How do i program my channels
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
6. When channel programming is complete, the message "COMPLETED"
7. Press CH UP or DOWN button to view the programmed channels.
Dec 14, 2010 | Toshiba 26HF85 26" TV
How do you set up the Soya TV. Is it cable ready?
Yes, your TV is cable ready. To set up, you will need to use the original remote and complete the following steps.
1. Connect your cable box to your TV using either antenna (RF) cable or component A/V
2. Press the "MENU" button on your remote
3. Select "CHANNELS" using the up/down arrow buttons on your remote and press "OK"
4. Select "SCAN CHANNEL" and press"OK".
5. Select "CABLE" as the source and press "OK" to tune
The TV should now automatically tune the cable stations and exit the menu. If you need to exit the menu and/or start again just press "MENU" on the remote again.
If you have no picture, press the "INPUT" button on your remote repeatedly until the input is on "TUNER" if you are using an RF cable or "COMPONENT" if you are using component A/V cable.
Your TV should now be setup for watching cable.
Please post back if you need further assistance.
Dec 05, 2010 | Soyo MT-SYTPT3218AB 32 in. LCD Television
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
How to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Nov 01, 2009 | Televison & Video
Tv problems
I am assuming that you are using cable and not an aerial/antenna.
On your concern "...channels do not tune...correct channel numbers...", it is possible that when you re-tuned the TV your setting was set to AIR or STD, try to re-tune again but this time pls verify that you are in CABLE mode. If on the other hand you are using aerial/antenna, then it is the other way around.
Channel 0 would automatically be your Audio/Video (which is where your DVD/VCR is connected). If you re-tune, chances are that Channel 0 ) would be back. To be on the safe side, pls power on likewise the DVD/VCR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Mar 04, 2008 | Konka K1938U 19" TV
Philips Magnavox 13MT143S 13" TV Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
